Question about Vacuums
DO you replace a power cord on a d3c rainbow as you do on the d4c ?
  • Vacuums Master
  • 18,392 Answers
Here is video witch may help you
Posted on Jan 09, 2013
SOURCE: I have a d4c rainbow vacuum, need help replacing the electrical cord
There is no reset button, but some of those old switches are very touchy . . . if there was some  corrosion, you may not have a good contact (was enough of the new wire insulation stripped away, before putting it into the switch) . . .
I prefer splicing, rather than going all the way to the switch  . . its just a matter of cutting out the old cord and splicing in the new cord in a convenient spot up in the motor compartment. . . a Rainbow purist would run the new cord all the way up into the power on/off rocker switch that's built into the top of the handle and then wire the new cord in there, directly at the switch . . . that way means no splicing . . . I've done it both ways, but I prefer to splice and use wire connectors inside the motor compartment . . . because going further, all the way up directly into the on/off switch just to avoid splicing the new cord in requires taking more things apart . . . and risks screwing up the power switch . . . that's not worth the extra time and trouble, IMHO.  (This from someone who has dismantled and refurbished over 200 D4C and SE models)
Posted on Feb 04, 2009
reddevil6
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
RockyNR1
  • 324 Answers
SOURCE: Power Switch
This is not that hard:
1. - remove gasket (it is glued so you may end up damaging it)
2. - remove 4 screws holding baffle
3. - under it you will see 4 more screws holding cap
4. - Four more screws and you will remove cap cover
5. - cut the cable tie, make a note how wires are connected, use flat screw driver to press on the latches holding the switch in while pushing onto the switch OUT. Tension will not let the latches pop back in.
6. - reassemble in the reverse order.
NOTE:
Switch - if you have old style switch installed you will need to push something into each hole next to the wires to release them. There is a cooper lip in each hole that you have to bend a bit to release each wire. Installing new style switch (with 4 wires) - attach one power cord wire to one blue switch wire and another to another blue switch wire. Attach one motor and one power nozzle cord receptacle wire to one black and another pair to another black wire.
Gasket - use weatherstripping glue to glue motor gasket back (you can get some in almost any automotive store)
Need parts - visit our store HERE.
No diagrams - sorry. It is Rexair, Inc. intellectual property and we can not use them...
Good Luck
Posted on Mar 12, 2009
SOURCE: rainbow vacuum model D4C leaks water,
you can buy them on line, there sticky on 1 side, you need too clean the area after removing the seal.be sure the areas clean so the seal will stick
  • 75 Answers
SOURCE: What's the difference between the rainbow D4C SE
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Posted on Jul 01, 2009
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
D3C RAINBOW VACUUM POWER CORD
if you mean you wont to replace the cord this video will show you
Jan 05, 2013 | Rainbow Technologies D4 Bagless Vacuum
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
What's the difference between the rainbow D4C SE and the D4C?
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
you have to splice them. Use crimp-on wire connectors (best), or threaded twist-on wire connectors. Do NOT just twist wire strands together and tape wires without using wire connectors . . . that is a NO-NO.
Jun 02, 2009 | Rainbow 75th Anniversary Canister Vacuum
Jan 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Jul 26, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
