Question about Nikon D80 Body Only Digital Camera
Everything on control panel is flashing. Can't operate camera.
Everything on control panel flashes even when camera is turned off. Can't call up menu or otherwise use camera.
  • shirley brand Jan 10, 2013
    All the settings are flashing and the control panel won't stop flashing even after i turn off the camera. The battery runs down and it finally stops flashing. Can't call up the menu or any other features while the flashing goes on.
  • shirley brand Jan 18, 2013
    I say "no" onloy because it looks like the camera is toast. I did try6 the suggested steps without success. I think it is probably more logical to buy a used D80 body and not face the expense and aggravation of having Nikon look at/fix the camera. I have had several years of successful family photography with the D80 so am not that unhappy about deciding to give up on the camera. I often think that technology can make life more complicated than they need to be.
  • Nikon Master
  • 3,289 Answers
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Posted on Jan 16, 2013
  • Steve Jan 18, 2013
    You can't go wrong with the D7000 - I've owned a D70 and upgraded to the D80 and finally to the D7000. A lot of the improved technology is useable - I love the high ISO settings. Call Nikon first tho - make sure they don't have a simple fix for the D80. Good luck!
Gryfox
  • 216 Answers
SOURCE: Nikon D70 (Control Panel.)
This is a known problem that is being repaired FREE of charge by Nikon. Go here for a form to fill out: http://www.nikonusa.com/email_images/nikonusa/service_advisory/d70.html
Posted on Nov 19, 2006
SOURCE: "Card" indicator flashes
2Gig max limit on memory cards for D1X
Posted on Sep 02, 2008
randy320sgi
  • 121 Answers
SOURCE: Nikon d80 won't turn on
Pcog3 & Guests,
Check to make sure (before you turn aon the camera) that the SD card is seated and lens is completely in the right position, if it's not the camera will malfunction and stay or turn off. The last guest that doesn't have info on the LCD can turn the menu items back on in the settings preferences.
randy320sgi
Posted on Jan 07, 2009
SOURCE: Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Posted on Feb 12, 2009
  • 11967 Answers
SOURCE: Monitor won't come on and iso keeps flashing in control panel
Set your ISO for auto ISO and see what happens.
Posted on Feb 28, 2010
Camera behaves as bulb even when on 1/100
Shut the flash off with the manual setting. it sounds like light censor problems. needs to be repaired.
Jan 20, 2013 | Canon EOS 550D Rebel T2i Digital Camera
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Mar 11, 2009 | Olympus Safe Hot Shoe to PC Sync Flash...
Using a speedlight sb800 off camera on a Nikon d80
Found a great website that explains this since it's not in any of the manuals or other websites I have searched for so long!
http://www.kenrockwell.com/nikon/ittlslave.htm
HOW TO DO IT
This covers the D70 and SB-600 which I use personally. It should be similar on other cameras. Any questions? Presuming you have USA equipment, call (800) NIKON-UX for details.
On your D300:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Flash cntrl for Built-in Flash
Move right and down to: C Commander Mode
On your D70:
Use P, S, A or M exposure mode.
Press MENU. Go to the yellow wrench menu, and be sure CSM MENU is set to DETAILED. Otherwise you won't see the next setting!
Go to the CSM menu which looks like a purple pencil. Set #19, Flash Mode, to "COMMANDER MODE." Further click to the right to set the commander mode to "TTL."
You also may set the commander mode to Manual or AA, which are other modes to fire the remote flash. The SB-600 only works with TTL and Manual. You set the manual power level at the camera.
Don't forget to POP UP THE BUILT-IN FLASH!
On your D200:
Press MENU.
Move right and down to: e3: Built-in Flash
Move right to get to a confusing panel of C Commander Mode settings.
Once in this confusing panel you can set everything for two external groups of flashes and the built-in flash. You move between the different fields by moving left and right, and set any field by toggling up and down.
In this panel you must select Channel, and set it to 3. Default is 1, which is the default for the SB-800. Don't ask me why they are different. Default for the SB-600 flash is channel 3, so if you forget this it won't work! Sorry about the complexity; Nikon didn't ask me for help here.
This is such a pain I use one of the D200's setting banks to store this.
On your SB-600:
Hold down ZOOM and "-" together to enter the CSM settings. That's why you see a gray "CSM" marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z-shaped arrow. This arrow refers to wireless communication between the flash and camera. When you see the wiggly arrow, press MODE to make it say ON.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
Presuming you did this correctly you'll see "CHannel 3" and "GROUP A" displayed. If you see different channels or groups then press MODE to get one or the other to flash and then the + or - buttons to set them back to 3 and A. No, I have no idea why these are the settings you have to use instead of 1 and A; 3 and A are what you need to talk to the D70's built in flash. If you get smart and choose others then it won't work. The other channels and groups are for people much smarter than I who want to try to rig up a zillion flashes to work together and control them all separately and remotely. I prefer professional studio strobes if I'm using more than one strobe at a time.
The SB-600 doesn't go into standby in this mode, so you can run down your batteries if you forget and leave it this way. It just sits there blinking its little red LEDs visible from the front.
HOW TO SHOOT
Easy, just shoot! If you set everything to TTL as I suggest then the camera just does everything. You and I are free to concentrate on the more important parts of making a great image.
Everything is controlled from your camera. This is very convenient if you have the strobes someplace remote, like duct taped behind plants.
You can control the remote flash's output simply by varying the flash exposure compensation control on the camera. You can do that without taking your eye away from the finder! You do that by pressing the same button you used to pop up the flash and then moving the front control wheel. You'll see the amount of compensation on both the camera's top LCD as well as through the finder. Brilliant! You can add more or less flash fill without having to walk over to the remote flash.
You can set the mode (TTL, Manual or AA) from the camera.
You can set the manual power level from the camera as well.
Try to have the little black window on the bottom right of the flash (marked with that same wiggly arrow) pointing in the general direction of the camera. Thankfully it's not a big deal; you don't even need a line of sight so long as the flash is anywhere near the camera or subject.
The sensor is sensitive enough to pick up the flash from the camera even if it has to bounce around a corner or off the subject. This makes this current system so much better than the older ones. You can hide flashes anyplace and even if they can't see the camera they usually go off correctly. They beep to let you know what's going on, even if you cant' see them.
The i-TTL system is much better than the old systems because it just works. If you ever used the older systems you'd know that half the time you'd get no flash, or a full-power flash that also wasted the shot. This new system just works, and that's critical for use in the field where the remote flash is rested on a garbage can or held in your left hand while you hold the camera with your right.
I even can have the flash in a different room out of view of the camera and it goes off just fine.
It works fine even 50 feet away. I haven't tried it any further. Honestly I have no need for a flash that far away; I was just seeing if it worked.
Jul 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Body Only Digital Camera Logo
96 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
