Question about Whirlpool Washing Machines
Whirlpool #LLR6144AQO will not agitate or spin. Motor Couplings good,agitator couplings good. Just a loud whining sound from the lower unit. Do you replace the gear case or can you rebuild it ?
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: washer will not agitate or spin
Hi
Thank You for using FixYa. If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 21, 2009
kdrake84
  • 262 Answers
SOURCE: Asking about WHIRLPOOL LBR5232EQ1 Agitates but
Have you checked the lid switch?
Posted on Feb 20, 2011
My Whirlpool Ultimate Care II LSB6300PW0 is about 6.5 years old. In the middle of a wash it started making a very loud humming noise. The machine wont agitate or spin. It still fills and drains the water...
Renee,
This might be too late for you but hope it helps!
I was able to fix a similar problem with the same model washer of a similar age so see if any of the following helps you.
Our washer died during a rinse/spin cycle and started making a horrific spinning/clicking sound when it was supposed to be agitating or spinning. It filled and drained like normal, and the horrific noise stopped when the lid was lifted.
Because of those two facts, I discovered it was likely the direct drive coupling, which connects the washer's motor to the transmission.
Turns out, that horrific sound was indeed the sound of one of the couplings spinning uselessly after it broke.
After some internet research, I discovered it was a simple matter of getting and installing the new coupling, which was very easy to do with a little professional help via YouTube:
Also, here is the website of a parts supplier with great schematics and great prices that I bought the part from.
Dec 22, 2010 | Whirlpool LSB6300PW Top Load Washer
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Washer will not agitate or spin
Hi
Thanks
Rylee
Dec 21, 2009 | Roper RAS6233KQ Top Load Washer
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Estate TAWB600EQ1 will not spin or agitate
If the washer does not agitate at all, does not spin, but will still drain, this is a symptom of a broken motor coupling.
The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair that doesn't cost much. The repair is actually much easier than you think and requires no special tools. The part number is included in the link I provided. Appliancepartspros.com carries a replacement motor coupling for about $11.
NOTE: A broken motor coupling is usually accompanied by a loud rattling noise. You can hear the motor engaging and running, but there is no tub action.
If you need an illustration, you can refer to the website I mentioned and locate item 13 under the Brake/Clutch/Gearcase/Motor/Pump section.
The motor coupling is located between the drive motor and the gearcase (transmission). It takes the place of a drive belt and commonly fails on Whirlpool manufactured top loaders due to normal wear and tear. This configuration is known as a "direct-drive" system. The replacement motor couplings are more resilient and resist breaking better, because the manufacturer added a steel grommet.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope you find this information helpful.
Oct 21, 2008 | Roper RAS8244KQ Top Load Washer
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
