Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My picture shrank and loss picture
First picture was expanding, and then the tv needed to warm up.. now we have no picture
  • Philips Master
  • 3,459 Answers
Common problem and a fairly easy DIY tv repair. Goto the site Tv Repair Kits and get their "video shrinking and expanding" fix for your model.
Posted on Apr 30, 2013
Picture flutters
If this is a projection TV and it shrinks and expands its a common issue with certain Philips TV sets. Sites like www.TvRepairKits.com have the kits to fix this.
Mar 30, 2012 | Televison & Video
Screen picture shrank by half
Do not laugh but usually if this happens (picture pulls down from top and or bottom) it is bad solder connections that develop from the age of the set.
The circuit boards expand when they heat up and contract when they cool down.
Usually in this case I exert pressure or tap on the main board and watch to see if picture opens up even for a moment.
Most likely place will be at Vertical output chip on main board; it is usually IC301 or 401 and is not real large; it will be mounted on a small piece of metal to keep it cool.
If you know someone who can solder and get the set apart it could be a ten minute job to correct it.
Most shops are going to be reluctant to work on a set this old so if you go that route call first and try to get a ballpark idea of costs.
These were really very good sets and had few problems but they are getting old now.
Let me know if you have any questions or need advice, I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Sony KV-32XBR48 32" TV
No picture, last night color was going away, then today no picture
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Desktop shrank and i can't get it to expand to the borders
Right click your mouse button on the desktop and choose properties. Then click on settings and then resize you resolution I like 1024 by 768
Good Luck
Proteus
Nov 23, 2009 | LG Flatron Ez T710BH 17" CRT Monitor
TV only shows line across middle of screen.Still have audio.
Sounds like you have bad solder joints on the vertical ic which should be numbered IC501 on the board.also there are capastors that coud be going bad but i would look for bad solder joints on ic frist.
The capastors numbers on board are C502 / C516 also need to check R 483 which is a resistor.
resolder the ic if you know how to solder. That is a comon problem a lot of tvs out there have. The only thing is the tv has high voltage on it even if it is unpluged from the wall. Some of the capastors hold there voltage for a long time. Be sure and unplug tv before you try anything if you are going to do it yourself and stay away from the capastor in the AC line should be marked 200 V or moor.
Mar 12, 2009 | Sanyo DS31590 31" TV
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Picture is extremely distorted
generally Samsung makes great units. but its definitely not worth fixing. recycle it and indvest in a new unit.
mj
Dec 22, 2008 | Samsung DynaFlat TX-P2775H 27" TV
Magnavox rear projectio9p6031c103 The picture quality is terrible
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Hope this helps,
Dec 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Loss of oil pressure
main bearings are worn and when heats up they expand even more and oil can blow out these with less pressure.
Oct 17, 2008 | 1991 GMC Sonoma
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
