Question about Toshiba Canvio E05A050CAU3XW 500 GB External Hard Drive - Black, Whi
Doesn't work, cable problem, don't recognize - Toshiba Canvio E05A050CAU3XW 500 GB External Hard Drive - Black, Whi
  • Toshiba Master
  • 27,725 Answers
Get another lead
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Posted on Jan 09, 2013
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
The router doesn't recognize the dsl modem. I have hooked up to the internet directly from the computer and modem-no problem using the same cable the router can't connect to the...
connect the Ethernet Cable to lan Port and make new connection from Window (PC also should connect to the Lan Port) and configure the username and Password (test it ) if it is going this mean the Wan Port Has some Problems......
Jul 12, 2011 | Computers & Internet
Computer will not recognize mp3 player, device doesn't light up
The two most likely causes for this is either your USB port or the USB cable itself. Try plugging the device into different ports and if that doesn't work, get yourself a different USB cable. If neither of those works then your device is faulty and the only fix for that is to get it serviced by the manufacturer.
Jul 02, 2011 | Computers & Internet
My computer does not recognize my printer
Your problem is very common and don't worry for this. First check the USB cable or try to connect with a new cable. If it doesn't help you then check settings printer and faxes in control panel. Make the printer online from settings. You can reload the driver.
Jun 03, 2011 | HP Officejet 5610 All-In-One InkJet...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I can't get my new MacBook to recognize and import photos.
Mac's don't need a driver to recognize the camera however they usually need a specific program for different brands of photos. You can also try opening up iPhoto as that will usually recognize the camera. If iPhoto doesn't work and you don't want to install a new program you can also get a card reader that'll connect via USB and will avoid needing any program to transfer photos.
May 11, 2011 | Fuji FinePix S1000FD Digital Camera
Toshiba Canvio E05A050CAU3XW 500 GB External Hard Drive - Black, Whi Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
