Question about Electric Razor Pocket Rocket Ride-on Motorcycle
I have the razor pocket rocket but i've ad one problem that even I can't seem to answer. when I pull back the throttle, it doesn't budge. The battery is charged, I have searched the wires
Bicycle controller box problems dysfunctional throttle (maybe) batteries are good the item itself is fairly new
    Genius:
  • 1,431 Answers
Try squeezing the brake lever first, some have a safety switch in the brake lever
Posted on Jan 10, 2013
  • 25 Answers
SOURCE: Pocket Mod -battery charged. when
none
Posted on Jun 21, 2011
aparsons89
  • 40 Answers
SOURCE: gt trailz currie scooter needs good battery
Hi, Is this the 12 volt 10 amp battery? If so go to ebay to buy this it will be much cheaper. You DO NOT have to buy the battery from Currie. For troubleshooting that control box, I will give you an link for it. http://www.electricscooterparts.com/troubleshooting.html
Posted on May 13, 2009
SOURCE: i got a razor pocket rocket and my back wheel blew
Replacing the rear tire is a real nightmare.....you are much better off purchasing the entire rear wheel assembly which you can do from the Australian distributors Funtastic for only about $10-$15 more than if you just bought the tire.
To replace the tire you need to use a bench vice which a couple of bolts clamped into it to hold the hub in place.....you then need to remove the sprocket assembly which is a reverse thread......i had to use a hammer and a large flat head screw driver wrapped in a rag so as not to tear up the teeth.
Once you've loosened the sprocket assembly you have to undo the bolts the hold the two sides of the wheel together and the tire will come right off.
All of this would be totally unecessary if they used a tire that you could remove just like any other mini motorcycle tire.
They don;t and so it is what it is.
As I said, next time just buy the whole assemble and then it's very straight forward.
Hope that helps!
Posted on Feb 20, 2010
SOURCE: Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Posted on Jun 21, 2010
youngdroop34
  • 11 Answers
SOURCE: Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Posted on Jul 08, 2012
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Jun 21, 2014 | Electric Razor Pocket Rocket Ride-on...
Razor pr200 pocket rocket. the tire is moving when i lift it up but when i sit on it it wont move
#1 check your power voltage on your batteries #2 you need to check the power to the electric motor - #3 possibly replace the control module - #4 possibly replace the throttle
Sep 06, 2013 | Electric Razor Pocket Rocket Ride-on...
My gas pocket bike lose power when going into full throttle?
sounds like a gas problem it could have a dirty air filter or carb needs cleaned or bad gas from siting to long or dirtty fuel filter
Mar 01, 2013 | Razor Pocket Rocket 155001
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
I found a pocket rocket in a junk pile. All the plastic is gone but the rest is there. When I turn on the on-off switch it lights up and so does the light on the throttle but the bike does not run. What...
check the batterys with a multimeter and make sure that they are showing the correct voltage, also visually inspect the batteries for any bulging, and if you can shake the batteries, if they sound like there is sand in them then they are dried up, and you'll need new ones
Jun 06, 2012 | Electric Razor Pocket Rocket Ride-on...
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
No power on back wheel just a red light on the off and on switch
try unplugging the brake wires. if this does not work, it is prob. your throttle.
Aug 05, 2010 | Electric Razor Pocket Rocket Ride-on...
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
233 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
