Question about Desa International CBN30T Central Heating System Heater
I need a thermostat for a comfort glow propane heater, model SL30PT, where do I find it
I need a thermostat and thermocouple for a comfort glow propane heater, model # SL 30PT. Where do I order it
2 Suggested Answers
SOURCE: Where is the model # located on my Comfort Glow propane heater?
Usually it is a metal plate stamped to the unit.
Most common places to find it is usually located where the gas
valve and burner is located, it could be hooked to a chain.
Sometimes it is located on the side.
-Good Luck
Posted on Jan 08, 2010
I have a comfort glow wall mountable natural gas heater. After being on for a while it shuts off. The model number is CGR18N. What cause's this
Either insufficient fresh air ventilation causing oxygen starvation or the safety thermocouple needs adjustment or replacement. Could be a bit of both...
Dec 04, 2016 | Comfort Glow Heating & Cooling
My propane gas wall heater does not turn off when it reaches its set temperature whats the problem
It has a thermostat that should shut it down, locate and clean if you can, try again , if it still is doing that have the temp sensor replaced
Jan 08, 2015 | Desa International Comfort Glow Infrared...
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
Just went down in the basement and checked on mine. Looking at it from the front there is a lable on the left side near the bottom. Mine has the model right on the top of the label. CBN18C is my model number, your should be similar to that, only it may have a LP instead of the N mine is natural gas....
Heatman101
Jan 08, 2010 | Desa International CBN30T Central Heating...
My husband and I recently purchased a house that has a Comfort Glow Vent-free Propane/LP gas compact fireplace 14,000 to 26,000 BTU/Hr with Thermostat. Model CGCFTP We need to light the pilot light and it...
Remove the small copper colores tubing going from the gas valve to the pilot assembly. Take it to a good hardware store that sells heaters and ask them for a new one.It is called a thermocouple.
Nov 18, 2009 | Desa International Heating & Cooling
My pilot light keeps going out on my comfort glow infrared propane heater what could be making it go out?
The thermocoupler is faulty. It is that bulb that sits i the pilot flame. It controls the gas valve so you won't get any gas if the pilot goes out.. So, the thermocoupler needs to be replaced. Inexpensive and easy fix. Good Luck _Ned_
Oct 19, 2009 | Heating & Cooling
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Open Questions:
Desa International CBN30T Central Heating System Heater Logo
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
