I have a toshiba satrelite L305 and one day i started it up and My mouse is stuck in the center of the screen and the battery wireless connection and volume show red x's. it also appears that my keyboard has locked because control alt delete does not bring up the task manager. The keyboard and mouse work in the startup screen. Any ideas? Thanks.
    New Friend:
    Problem Solver:
  • 12 Answers
The cpu get hot , fan is not working.
Posted on Jan 09, 2013
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Posted on Aug 15, 2009
  • 94 Answers
SOURCE: My HP Pavillion dv6000 laptop now the Mute is
You have two options (1) Troubleshoot the PC (2) restore factory settings
Posted on Dec 06, 2009
Testimonial: "Thanks - I had been troubleshooting to no avail. I went to HP and downloaded the BIOS which was not the right one. HP emailed me the right BIOS. "
My Toshiba Satellite L305-S5921 won't connect wireless or wired to my internet it shows the net works and signals and can be connected to the router but ends up with local or limited service I've reset the...
Try disconnect the router and connect your laptop to the dsl modem. If there is connection then the router may have problems. If the problem persists then go to toshiba service center. They will certainly solve your problem. It might be that there are problems on hardware or drivers.
Jan 30, 2011 | Toshiba Satellite L305-S5921 Notebook
WHEN I TURN MY PC ON THE SCREEN CANT START UP ITS DARK AND I WANNA KNOW THE PROBLEM AND THE COST OF THIS
try to remove the battery then connect the power an try to on the laptop if it works then shutdown the laptop an reconnect the battery then on,if not then if possible remove the memory from back portion by removing the screw then clean the memory an put it back if not sorted the u have to take it to a Toshiba service center ,the cost for the system board may be some ten to twelve thousand rupees
thanks for the query happy to help you fixya team
Dec 21, 2010 | Toshiba Satellite L305-S5911 Notebook PC
Toshiba satellite L305-S5919 wont start up. Its on a black screen with the mouse arrow icon in the middle.
I would love to know how to solve this problem. I have the same problem on my daughter's laptop!
Nov 21, 2010 | Toshiba Computers & Internet
Toshiba media recovery satellite l300 series windows vista home premium disk doesn't work it gets stuck on a black screen with a mouse cursor
Try cleaning the disk in soap and water / dry with a microfiber cloth or cotton towel . Then try your disk. If you don't get the proper response then I suspect a corrupt data disk or a malfunctioning DVD.
May 09, 2010 | Toshiba Satellite L305-S5907 Laptop
Connection procedure for Toshiba N745 mouse needed.
I don't know if this is the same as my mouse. However I have a satellite1955-S803 with wireless detachable keyboard and full sized optical wireless mouse. The original owner said it came with the laptop.
First I tried very hard to get the keyboard working. After a frustrating day of calling Toshiba, I noticed the "detachable" latches. I removed the keyboard to find a battery compartment. 4 days go by with me calling Toshiba trying to get a replacement. Finally found a battery at batteries plus that does work. about half the mAhr of the original but hey it works.
Now to the mouse. Replaced the AA's batteries but couldn't tie the mouse to the computer. I run linux so no M$ driver would help. Finally found a PDF of the manual and it says "if the mouse has trouble activating, press the wireless mouse button on the laptop."
That button is on the front left edge of the laptop (where the "Intel inside", "XP loaded", and "nvidia" stickers are located ) just to the left of the front silver "mode" button. Under the mouse press the connect button. (round near the optic laser but un-labled) then press the wireless mouse button on the computer and there you go. It just connects and works.
2 weeks I looked for this and it was just that simple.
Aug 26, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Cannot use wireless mouse or laptop pad for cursor functions.
Rosemary,
This is a very common problem with many Toshiba laptops.
The cause is the bios on the motherboard.
The best way to get the computer working again is to contact a local authorized Toshiba center.
They are still repairing the problem for FREE.
So make sure you don't pay!
Here's a link to Toshiba's repair center finder.
Make sure you call them FIRST before taking your computer to them.
Best of luck!
Jun 15, 2009 | Toshiba Satellite L305-S5933 Notebook
Please how do i get to activate a toshiba wireless mouse
just connect the transiever(the usb part) to the USB port.normally it will be recognized automatically. If not you shoul install the drivers. Dont forget to put batteries in the mouse. After that you should set up the connection between the transciever and the mouse. in most wireless mice there is a deep button under the mouse or hidden in the battery compartment you should push it and then push the button on the transciever( in some cases in the opposite order; first the transcievers button then the mouses button). usually an LED indicates that the connection have succeeded( either on the mouse or the transiever )
LEDs condition:
flashing on/off not connected.
continuous ON means connected.
Hope it helps
BR
/BS
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Blinkink mouse OMC90S
Is it wireless?? if it is then the batteries might of gone on it . if it is wireless then maybe the wire isnt connected correctly into your tower? another solution maybe that its a bit stiff ? just check your tower and make sure its connected up correctly. Hope i helped
Oct 17, 2007 | Creative Labs (OMC90S4L) Mouse
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
