Question about Plumbing
Pressure in captive air tank on water pump keeps rising
I checked and set the pressure in my captive air tank by the proper procedure to 40 pounds( shut off pump, drain system of all pressure , check tank pressure, set to 2 pounds below cut-in pressure of pump). After a short ime noticed that my water pressure would drop to almost nothing before the pump kicked on; a classic symptom of the pressure in the captive air tank being too high. When I checked the pressure in the tank again, by the same method (pressure drained from system) it read 55 pounds. I thought I screwed up so I readjusted the pressure to 40 pounds. The next day the same thing occurred. I checked the pressure in the tank (again, after draining the system) and the pressure was back above 50 pounds. Yesterday I set the pressure at 10 pounds. The water pressure in the house seems good now. I checked the pressure in the tank (again after draining the system pressure) and it's now at 13 pounds. Can someone please explain how the air bag is gaining pressure???
3 Suggested Answers
  • 523 Answers
SOURCE: I have a Flotec FP 4022-10 3/4 hp shallow well
If heating up, the motor thermal switch is opening to shut down the motor; this is by design. During the brief run time does it pump at all? It sounds as if there may be mechanical issues on the pump itself and the motor (from the extra draw) is heating up and shutting down. I'd look in to the pump to see if anything had failed within it.
I hope this may have helped,
Tom
Posted on Sep 25, 2009
  • 523 Answers
SOURCE: gould 1/2hp submergible well pump cycles on and
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
Tom
Posted on Oct 12, 2009
Should Ebrs watertech pressure pump come on and shut up with use of tap
No. It sounds like you have lost your air bubble or air bladder in your captive air tank. Without the elastic effect of an air bladder or air bubble in your captive air tank, the pump will come on right away, trying to keep up with demand for water. You will have to either add air to the bladder in your captive air tank (it looks like a car tire valve stem) so the pressure is likely in the 35-50 lbs range. You may have to flush a toilet or have other water usage going on when you will the tank with air or you will be fighting your water pump. Or, turn the pump off, flush a toilet, and then will it with air to the approximate pressure, then turn the pump on for normal operation. If the problem comes back, you will need to possibly replace the captive air tank and or bladder, which if ruptured is letting air dissolve into the water, leaving you again with not elastic bubble to act as an accumulator.
Jan 23, 2018 | Plumbing
How much air should be in the bladder bag in a 36 gallon captive air tank
The air pressure in the tank should be two psi below your pump cut-on pressure (i.e. 18 psi with 20-40 psi pump cut-on/cut-off or 28 psi with 30-50 psi pump cut-on/cut-off).
Oct 03, 2017 | Plumbing
When a tap is turned on the pump keeps clicking on and off instedy of steady
It sounds like your water holding tank needs air. You could just add some air and see if that helps. The proper way is to shut the power off going to the pump. Next open up a spigot until there is no water coming out. Then close the spigot. Now check the air pressure in the tank. Water tanks come with a tire valve installed, so all you need is a tire pressure gauge. There should be a label on the tank that will tell you how much the air pressure should be. As I recall, it should be around 38 lbs. But, that would depend on the pressure switch that is installed on your pump. A common one used is 40/60. To add air use an air compressor with a tire chuck. You could also use a bicycle pump. When the tank is at the correct pressure turn the power, going to the pump, back on. That's it. Additional info: Your tank should have an air valve located somewhere on the tank, usually on top. You add air the same way you add air to a tire. Through the air valve. If there is no valve, consider replacing the tank with a tank that does have a valve.
Jun 24, 2015 | Plumbing
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
I have a flotec shallow well pump i can not get it to pump the water it stays at 20 pounds did i hook it up wromg
check your pressure tank. It sounds like it is water logged. This means there is no air pressure in it. If you're cut in pressure is set at 30 pounds you must have 30 psi of air pressure in the pressure tank.
Oct 01, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
No more then 30 pounds of presure and wont shut off. Flotec water
If the pressure does not get pass 30 psi, then check for leaks along the pipelines and on the tank itself. An air leak on the top portion of the tank can cause the pressure not to trigger the pressure switch. Use soap bubbles to detect any air leak. Although a stuck pressure is not more likely the problem, check it also.
Aug 31, 2009 | Flotec 1/2 Hp Stainless Steel Waterfall...
Water pump cycles to often. When pump turns on, pressure gauge shoots up to 50 lbs right away without pumping much water.
Sounds like a well fed system with a pressure tank that has lost its air charge. Check for a water tank with a tire pressure type stem fitting, should also have a pressure gauge. Most newer tanks have a rubber diaphram inside to keep the air and water from mixing, but a lot of older ones don't and the newer ones will develope a leak that will produce the simpoms you describe. Try adding a few pounds of air pressure to the top of the tank and check for leaks. Warning: Compressed air can escape explosivly if the tank is badly rusted out but if your water pressure goes to 50# without the tank leaking, it should be safe to add up to 25# of air. The air charges the water system and allows the pump to shut off until enough water is used to lower the pressure back to set points on the control switch. It's not a good idea to adjust the set points on the switch unless all parts in the system have been checked for safety to the new pressures.
Aug 13, 2009 | Water Heaters
Plumbing Logo
215 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
