Does not dry. is there a filter that needs to be cleaned
    New Friend:
So is this a Washing machine or a Dryer? It is hard to tell with these front loaders. If it is a Washing machine it is not suppose to dry.
If it is a Washer: Do you mean it is not spinning the close to squeeze most of the water out before you put them in the dryer?
If it is a Dryer: There is usually a lint trap just inside the door. However, if that is clean then you could have lint building up in the hose behind the dryer where it is supposed to vent outside. Sometimes that hose gets squashed between the dryer and the wall and doesn't allow the lint to move freely out of the tube. You can remove it and clean it out with your vacuum cleaner.
Posted on Jan 09, 2013
How do you clean filters
What filters are you cleaning. If it's electrostatic air filters, these can be soaked in a plastic tub full of warm water and a small amount of dish soap. I also use about a half cup of bleach per 5 gallons water. Soak for 5-10 mins then rinse with water hose. Allow them to completely dry before reinstalling. If you are cleaning a washable air filter, clean with you water hose, spraying the direction opposite the normal air flow. Should be a arrow showing wash direction. Not sure of what you want to clean but I hope this helps.
Aug 19, 2017 | Heating & Cooling
Machine says clean filter, have cleaned filter but still wont dry?
Has it overheated and maybe blown a fusible link?
Jan 20, 2015 | Dryers
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
What does code E2 mean
E2 Indicates that the filter needs to be removed and cleaned. It's a good idea to clean the filter at least once every 2 weeks, as standard routine maintenance. Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before removing and cleaning the filter. You can access the filter by pulling on the filter frame handle on the right side of the unit, behind the front louvers. You can either vacuum the filter or wash it in warm soapy water (dish washing detergent), rinse it and dry it thoroughly, before reinstalling it. A hand held hair dryer will dry it pretty fast.
Hope this helped you to solve the problem.
Jun 11, 2011 | Haier 45-Pint Dehumidifier
Shortly after I turn on the sanitizer on the machine, it turns itself off (the whole machine). Does it need to be cleaned?? What type of solution do I clean the boards in??
Remove the plaques and using an old tooth brush clean with mild soap and water.. Rinse thoroughly, towel dry and finish drying them with blow drier. The interior of the unit and it's filter should also be cleaned. Depending on what type filer it uses (Aluminum mesh or soft mesh plastic) they too and can be washed with mild soap and water, rinsed and thoroughly dried. Any other type filter material may need to be replaced. Clean the interior with canned compressed air with a straw nozzle and a dry paper towel.
Of course, before you do any of the above, unplug the unit.
Mar 02, 2011 | Ecoquest Breeze AT Living Air Purifier
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Does not dry thoroughly in sensor mode heard that softner sheets may require cleaning the sensor . How do you find and clean sensor.
First, I always set the dryness level at the maximum dry level, because the Korean's "Normal Dry" is what we call "Damp Dry". The sensor is located just inside the door, by the lint filter. If you stick your head into the dryer drum and look back toward the filter you will see it. (two curved metal bars, about an inch apart and about 5 inches long.) Clean with soap and water, or I've heard rubbing alcohol works. If your sensor bars need cleaning, the dryer usually will go quickly to the 6 minute mark after starting.
Oct 16, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Cleaning filter for quietmaster SM18L30
yes basically you wash with soap and water and let it dry you can also blow dry the filter.
i hope this helps.
Jun 26, 2009 | Friedrich QuietMaster SM18L30 Air...
Washing Machines Logo
Top Washing Machines Experts
