Question about Nordic Track NordicTrack Commercial 1500 Treadmill
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
I have a Nordic track  commercial1500 and the belt - 1_9_2013_6_44_05_pm.jpg1_9_2013_6_44_19_pm.gif
Posted on Jan 09, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Posted on Jun 20, 2012
My tread mill belt will not run. it suddenly stopped working when i stood on it. there seems to be power to everything else
LUBE the deck belt with grease or WD-40 o any silicone lube.
try to loose the belt deck in the way that when you lift with you finger will be 2" max. See the drive belt , must have a deflection with your finger 1/4" aprox. Of course time to maintenance motor: lube the bearing or replace, and the carbon brush. Lube the deck bel 1time every week.
However you must test the voltage to the terminal to the motor from 0-180 Vdc, if NOT replace the Motor control Board
Feb 08, 2015 | Nordic Track Nordictrack 3500r Treadmill...
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
My Nordic track 1500 motor will not run, everything else still works????
Step 1:
1) test the input voltage motor,if there are the motor need repair,see the diagram attached, and see my personal TIPS for motor help
Step 2:
tes the output voltage board, for input voltage motor, if there are NOT the board is faulty, replace see the block d.
God bless you
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
Belt on Nordic Track T4.0 treadmill stops
Dear Sir:
1) Lube the treadmill in according with the instruction manual.
2) The reason is lack of lube by maintenance, that produce enough friction with shut down for to protect electronic system.
3) Test the deck belt if is worn, and replace it.
4) Test the rollers bearings
5) See the bearing motor
6) Test the input voltage motor coming from the output from the main motor board,, use DVOM.
7) See my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Nordic Track Exercise & Fitness
Motor not turning on nordictrack c2500
1) Lube very well the deck belt, maybe you have deck belt worn by lack of maintenance schedule proceed with the instructio manuall , and adjust it.
2) Test the drive belt and replace it.
2a) LUBE the rollers bearing front, and rear
3) Test the input voltage motor, if there are , the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are not the board is faulty.
5) Try to run the software calibration for diagnose, and troubleshooting.
Apr 18, 2012 | Nordic Track Exercise & Fitness
Belt slips when running
check the tension on the w/ belt,if good your motor belt is worn out.
Mar 09, 2011 | Nordic Track Nordictrack Exp 1000...
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Nov 12, 2009 | Nordic Track /proform Treadmill...
My Nordic track 1000 runs great for about 25 minutes then the belt stops working. The display is working. I have to use the stop button and wait a minute to restart the track. Then it will only run for a...
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt.
Nov 09, 2009 | Nordic Track Exercise & Fitness
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
133 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
