Question about Numark MP-102 CD Player
Numark MP 102 MP3 cd player shows "Tray Error"--need fix.
    New Friend:
    Problem Solver:
  • 8 Answers
NEED TO CHANGE THE LENSE
Posted on Oct 05, 2013
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
NUMARK MP102 - When we put in an audio CD the CD sounds like it is spinning but the display says "NO DISC". Thank you in advance for your time.
it could be bunch of ting 1clean lens with soft cloth 2 it could be wrong disc,check n see if it as digital audio compatibility cd or it the unit just not reading the disc i think it is the wrong disc
Aug 03, 2011 | Numark MP-102 CD Player
When you put a cd in it reads no disc for normal cds but plays all burned cds. I have a numark MP 102. What can I do/
open your cd and then clean the and sensor with cotton and slowly and well manner and then try..
Apr 12, 2011 | Audio Players & Recorders
We use our setup for group fitness classes and it can be a bit of a pain in the backside at times it will play a cd when you press the pause button all is good press it again to play and it will just start...
Be sure the CD''s are clean. Remember, contrary to a vinyl record, do NOT clean them in a circular motion. Always use a soft cloth, tiny amount of non-ammonia window cleaner, straight from center to edge. If the cd's are clean and it affects all cd's, (not just one or 2..) The the model 102 has to be serviced professionally- preferably by the factory. I have had quite a few over the years that I've shipped to the factories and they come back as good as new.
Nov 02, 2017 | Numark MP-102 CD Player
Powers on fine, but won't eject tray.
There's a small rubber belt driven by a motor that turns the gear which moves the tray. It's probably stretched and is slipping. You can usually get at the belt by manually opening the tray and removing the cover from the player. There's usually a small hole on the under the tray where you can insert a straightened-out paper clip to open the tray. A TV or stereo shop can probably help you find a replacement belt, or you can order from online suppliers. Measure the belt circumference, and get one about 10% smaller since the old one is stretched.
Mar 08, 2010 | Numark MP-102 CD Player
Right side cd player shows error on screen and is not recognizing a cd in there (shows error)
You have a mechanical problem with CD drive. Needs to be replaced. Let me know if you need help. digitalrepair@hotmail.com
Jan 27, 2010 | Nu Mark Numark CD-Mix-2 Dual CD...
Drive a will not open- display shows error
I repaired a couple of these before and the problem was in the loading mechanism,under the tray there is the loading motor and a drive belt that connects it to the gears ***`y, if youre a handyman you can take it out but be careful and look how you dismantle/reassemble the tray, also look for dried up grease on the gears center hub.
Nov 02, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Spins CD but displays"read " but plays nothing
Hi, this is CD lens assembly failure. the len sits in a lens assembly that has a motor that allows it to travel along a rail. this is how it reads the CD in motion. this assembly has failed and , you will need to replace this mechanism in order for the lens to be able to read once more.
May 17, 2009 | Numark MP-102 CD Player
Tray won't open, no buttons work
Return it. do not open it up or you will void any warranty. There is either a disconnected cable or a logic/power problem. In any case, a new piece should work out of the box.
Dan
Apr 10, 2008 | Numark MP-102 CD Player
Numark MP-102 CD Player Logo
155 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
