Question about Watches
I cannot set the time on my Champion LA10 watch
The instruction manual is for Champion watch models LA06/LA07/LA10/GT10. These are the instructions: (http://www.genevawatchgroup.com/pdf/Champion/C9_by_Champion_Watch_Instructions(LA06-LA07-LA10-GT10-GT14).pdf). Step 3 does not work for me. I have tried at least 20 times, and holding S2 for 2 seconds does not cause the message "SET" to appear, and no digits blink. I know that it should work, because once it did work, but I accidentally pressed the wrong button. Since then, it has not worked. What am I doing wrong?
SOURCE: need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Posted on Mar 10, 2009
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Posted on Jul 30, 2008
SOURCE: lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Posted on Feb 17, 2009
SOURCE: How do I set the digital time on a mossimo
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Posted on Apr 20, 2009
SOURCE: Acqua Indiglo watch
Can't understand instructions
Posted on Aug 31, 2009
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How to put the time vestal watch
Hi Margarita,
  • It depends on which Vestal Watch model you have. Look on the back of the
  • caseback and it will have the model name. Then go to the Vestal Watch website
  • (www.vestalwatch.com) and look for your model name. Click on it and then click
  • on the instructions manual link to the right of the watch image. You can also
  • request a PDF of the instruction manual by emailing info@vestalwatch.com. If
  • you've done both of these things and still no luck, then call 949-631-7036 and
  • ask for instructions on how to set that specific model.
May 03, 2014 | Watches
How to set my c9 champion watch date, day, time
Hold the bottom right button (lap/reset) until it beeps and comes up with "SET". The bottom left button (mode) will alternate between what you are increasing (Hour, minute, month, day, ect) and the top right (start/stop) will increase it by one (hold to make it go faster). When done, just hit the bottom right button again.
Jul 29, 2012 | Watches
I want to set up for manual instruction. when i started to set up, but time is coming true ..then date is automatically changes...i need instruction for manual.. and How to use L.Y +1 +2 +3 ...I can not...
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Mar 18, 2011 | Citizen 8700 BL8000-54L Wrist Watch
How to set the time for citizen eco drive skyhawk.
Hi, This watch is Calibre C651, same as Model #JR3090-58M (Promaster Air Collection - Blue Angels Skyhawk). C651 is not available on Citizen website, but you can use Calibre C650 instructions. Download PDF manual and follow instructions on page 3. They are pretty detailed, so take your time, and you should be successful. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number (C651 or C650 in this case) from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 06, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I HAVE THE MODEL 1D0510 CITIZEN BLUE ANGELS AND I DON'T KNOW HOW TO SET THE TIME. PLEASE BE SO KIND TO SEND ME BY MAIL INSTRUCTIONS IN ORDER TO FIX IT. KIND REGARDS
Hi, I'm not familar with that model number, but I believe it's the setting procedure as the Skyhawk C650-C651 Caliber. C651 is not available on Citizen website, but you can use Calibre C650 instructions. Download PDF manual and follow instructions on page 3. They are pretty detailed, so take your time, and you should be successful. If you don't have the manual, Try this link:
Sep 06, 2010 | Citizen Blue Angels Skyhawk Watch
Time setting instructions missing
Go to http://www.nike.com/timing/ choose your region and click on "support".
In the menu on the left is a box called "All manuals"; Scroll down until you reach your model and download yior instructions.
May 09, 2010 | Nike Presto WT0001-901 Wrist Watch
Lost manual to Coleman nightsight watch and need to set time and date
The manuals for Coleman watches are at this website. . .
http://www.gsi-usa.com/instructions/
You need to look at the back of your watch to get the model number.
Jul 30, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Watches Logo
317 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
