Question about HP Pavilion G7-1167Dx Laptop / Amd Phenom Ii Quad-Core Processor
HP Pavilion g-7 will power on, Fans on, No screen, Nothing else
Fan comes on and then nothing else happens.
  • HP Master
  • 27,725 Answers
You have posted in webcam problems !! you might be better posting in laptops
If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Posted on Jan 09, 2013
HP Pavilion power problem?
The power is coming to System , but its not getting supplied to other hardware devices via motherboard.
The Problem can be with your motherboard.
Try removing the Auxilary port wire ,which is a small wire which is connected near the FAN , the wire comes from SMPS(power supplier) to the motherboard.
hope this helps
Jun 07, 2012 | HP Pavilion Elite M9060N PC Desktop
PC turns on, fans running, but nothing getting thru to the monitor. Getting string of 2 long beeps, non-stop Note: was watching a video on YouTube when the picture just froze and nothing would stop it...
have you just installed new ram? this usually happens when the wrong dimms of ram have been installed. try taking all them out and leaving just one stick of ram and turn on again.
please let me know if this helps.
i will do my best to assist you
Jun 11, 2011 | HP Pavilion p6210f Desktop 26GHz 6GB...
When i turn on my HP Pavilion a1320n nothing happens. it sounds as if it is in standby mode and the fan is runing but the monitor never comes on. i can't get it to the initial dell screen where you can...
id check and reseat memory ram first. it should give you a beep sound for error. if nothing, then check video card and hard drive. you can also remove everything (ram, hard drive, cd or dvd rom) then restart and see if it gives a beep error.
https://kb.iu.edu/d/afzy
May 03, 2017 | HP Pavilion Media Center a1320n PC...
HP Pavilion G7-1167Dx Laptop / Amd Phenom Ii Quad-Core Processor Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
