Question about Kenmore 63942 Dryer
Kenmore dryer model 110 60852990 when the button is pressed you hear a buzz but the drum does not turn. the inner light works so it is getting electricity. canyou please help
The dryer is about 10 years old
catriver
  • 878 Answers
SOURCE: An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Posted on Jan 04, 2007
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
Drum will not turn and there is a buzzing sound when start button is pressed. How do you access the drum or motor on the Kenmore Elite Model #592-89309?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Dryers
Basic order of troubleshoot - gas dryer, electric on (light on when opened), won't rotate or start, hear buzzing when pushing button. No section for Kenmore 70901 gas dryer on this site. I want basic order...
Buzzing as in end cycle tone? That would indicate a stuck switch on the motor and freeing it would buy time until new motor could be installed. Low humm as in motor is stuck and cannot turn would require removing belt and see if motor is stuck, drum is stuck or something in exhaust fan holding it back.
Eric
Jun 11, 2010 | Kenmore Dryers
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 electric dryer drum does not turn
Yes it should turn by hand and may be easier one direction than the other. It could be as simple as something stuck in the blower preventing the fan from turning. This also stops the motor from turning. Worst case is a froze bearing on the motor but I would pull the fan cover off and see what is in there.
Eric
Let me know what you find as I have found some very interesting things in the fan over the years....
Jun 09, 2009 | Kenmore 659 Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Gas dryer drum does not spin
defective motor,,replace,,,onthejob
Jan 11, 2009 | Dryers
Gas dryer drum will not spin
the flint element might need to be replace...(pilot light) I had the same problem the dry had a burned smell...which meant that the element wasn't working properly and finally the drying wound't heat anymore
Jan 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 63942 Dryer Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
