Question about HP Officejet 4110 All-In-One InkJet Printer
How do you use the scanner?
I put a picture in to scan and press scan. It says that its, "starting scan" and then nothing happens. Am i doing something wrong? Please tell me how to use this feature.
  • 1 more comment
  • mngirlintx Jan 29, 2009
    I have the same issue. It says starting scan and absolutely nothing happens.
  • jonathanhein Feb 23, 2009
    trying to scan on officejet 4110 using my sony vaio vista and it gives me the following: failed to create file c:\scan0001.tif
  • morhow20 Feb 28, 2009
    Trying to scan anything such as a picture and it indicates "starting scan" but nothing happens.
    President:
  • 2,692 Answers
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
I placed a picture over the scanner glass and tried to scan it by pressing the scan key, but nothing happened Do I have to change any settings on my computer or brother machine? Please let me...
you do not change any setting on your computer and on your machine: the machine work as a scanner, if you click the scan Botton, you should go to scan utility on your computer and click the scan command to receive the numeric format of the original image placed on the glass, if you need help about '' how do you scan a documemt '' : 1) click the start botton 2) go to control panel 3) click twice on the scanner and photo 4) the assistant will guide you to scan your photo. if my solution helped you don't forget to vote.
Nov 07, 2010 | Brother MFC495CW
How do i scan with HP PSC 1315 all in one inkjet.
Go to -Start-There should be "printers and faxes".Click it,on the left side is "other places",under that heading is "scanners and cameras".Click it and it will bring up your scanner.Click to highlight it,then click "get pictures" in the left column.This will initiate the scanning process.
You can also get there thru "Control Panel" if printers and faxes isn't available in the start menu.Good luck!
Jan 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
I press Scan but nothing happens. How do I scan on Canon MP160?
Make sure the scanner is connected to your laptop/PC before you press 'scan'.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
When pressing scanner to computer button nothing happens
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 2500 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
May 09, 2009 | Lexmark X2550 All-In-One Printer
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Scanning
hmmm...did you try this from the HP print manager on your computer?
that will help with deciding if it's a scanner issue, or maybe more like firmware.
www.hp.com
has that print manager.
Jun 01, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
248 people viewed this question
Seeker5211
Seeker5211
