Question about HP Pavilion Computers & Internet
Connect to firewire through usb 3.0 - Pavilion HP Computers & Internet
  • HP Master
  • 2,386 Answers
USB (1.1, 2.0, and 3.0) are based on completely different specs than Firewire (400 and 800). Even the way they interact with the processor and memory is completely different. They are not wire-compatible, or even signal-compatible. In order to convert a a Firewire connection into a USB connection, you would need a computer with both ports, have it convert the Firewire signal into binary, then convert the binary into a USB signal and send it out. This hasn't even touched on the problem of having the device show up properly to the end computer. It's a complex problem that hasn't be tackled because there is so little demand for it, especially considering the price that would be asked for such a device.
If you use Expresscard solely for Firewire, I say ditch Expresscard and find something with built in Firewire. It's growing more uncommon for it to be included on consumer laptops, but it's still widely available on business models, which also tend to be significantly higher in quality.
Posted on Jan 09, 2013
Firewire 800
I don't know, but regardless, if you have a firewire connector on your laptop, it will work. If old like mine, even if the camcorder is firewire 800 ready, made for 800, it will run at 400 (just like my laptop can do USB 2 but cannot do usb 3... so it sends at USB 2 speeds.) The firewire connectors look the same for both 400 and 800 btw. <:0} So it doesn't really matter.
May 29, 2013 | HP Compaq 6910p Notebook
Tip
How to connect an iPod to a computer connection
<p>The iPod is one of the world's most popular MP3 players because of its ease of use. You can simply drag and drop video and audio files from your computer to the device to your collection on-the-go media to expand. The process of establishing this connection with your computer is easy, and maker of the iPod, Apple only requires that the freedom of the media management program, iTunes downloads to begin adding audio and video on your iPod. <br /> <p><br /> <p>1. Identify your hardware. If you use a computer with a USB 2.0 port, then you have it easier because all you have to do is plug in your hardware. If you are using an older computer (usually with an operating system to Windows 2000), then you have a USB 2.0 port, in which case you should consider using a FireWire or USB 1.1. If you do not have FireWire or USB 1.1, you need a card or adapter. <br /> <p><br /> <p>2. Identify your iPod. Fifth-generation iPods or later can be connected using standard FireWire adapter cable option, but otherwise requires USB 2.0 ports. You can also use standard iPod USB 1.1 ports, but it requires an adapter. The Nano and Shuffle models can only connect via USB ports. <br /> <p><br /> <p>3. Connect the iPod cable that you use on your iPod. The larger end of the cable should fit in the bottom of your iPod, whether it is a standard FireWire cable or dock to the USB 2.0 connection. <br /> <p><br /> <p>4. Connect the other end of the cable to the designated location. For USB users, this will be a USB port on your computer. If you use FireWire, and connect it to four or six-pin FireWire is not. <br /> <p><br /> <p>5. Download and install iTunes if you do not have the software. It is a free program your iPod. If you had installed before establishing the connection, it will open and audio / visual files or on their own. After transferring to your iPod files to load or eject. <br />
on Aug 09, 2011 | Apple iPod touch
Where/how do I connect the USB 3.0 PCI Express Interface Card IFC-EC2U3/UC, Internal Power Cable? I'm about to buy one and other cards I've used for Firewire/USB 2 expansion did not require an internal...
USB 3 provides extra power though the port that firewire and USB 2 do not, as such it will need to be connected to your power supply. They should include a adapter cable to go from a molex connector to the format on your USB 3 board.
Hope that helped clear things up
Dustin
Feb 04, 2011 | Computers & Internet
External n256 firewire connection does not identify
I would think you need to enable your firewire in the BIOS
Nov 13, 2008 | Maxtor Hard Drive
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Installing Firewire 400 on a Western Digital 500gb external My Book Pro
Don't connect the USB and firewire at the same time, use one or the other. In general for USB, for the very first connection, it is better to have the computer fully booted, and the MyBook spun up, before connecting the USB cable. After that, you can boot the computer with or without the MyBook connected or turned on. For the firewire connection, check your manual for the correct order of connection and power on.
USB and firewire 400 are roughly comparable. USB is theoretically a little faster, but you will see little difference. There are other factors that can affect your actual performance, so your best answer is to try a test yourself. Time a copy of a very large file, and a copy of a folder with a very large number of files.
Dec 03, 2007 | Western Digital MyBook Pro WDG1T5000 500...
USB Connection Problems
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
USB 2.0 vs. Filrewire - video to PC
Hi I have figured it out. Even if the USB 2.0 is faster than the firewire the camcorder itself do not transfer at the optimal speed when connecting with the USB (even id the USB can transfer faster). So the only fast transfer option is the firewire
Sep 06, 2005 | Panasonic AG-185 Camcorder
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
