Can I copy documents to a flash drive using my fax/scanner machine?
    Problem Solver:
  • 10 Answers
Posted on Jan 20, 2009
When we send a fax the receiving party only gets a black sheet. how do we fix this? we have tried changing the contrast and resolution and cleaning the scanner and nothing is helping.
Your document scanner has failed. Verify by making a copy with the machine. If it comes out black then your document scanner is dead. It will be cheaper to replace the fax machine rather than repair it. These types of machines have come down in price making it no longer feasable to make such a major repair.
Good Luck and Thank You for using Fixya.
Nov 12, 2010 | Brother IntelliFAX 4100 Laser Fax
When I send a fax, the recipient gets all dark or black sheet. Thinking this was the recipients problem, I faxed again to a different fax number, same thing happened.
To fix the problem you have to check the scanner of your fax machine. It might not be functioning properly. Try to observe the fax machine while sending a document, look at the scanner section and see if the light of the scanner is turned on or lighted. If it's no longer lighted you have to replace it.
Nov 07, 2010 | Sharp UX 355L Plain Paper Thermal transfer...
Receiving faxes alright, people receiving faxes from us are getting an all black page
Your document scanner has died. Meaning that the row of LED's that light up to scan the documents you are trying to fax are not lighting up. The result is a scanned document that is read as all black. Make a will get a black sheet because the same process is used to scan the document when making copies.
It might be time for a new fax machine as these machines have become so cheap to buy new that I doubt you could get this machine repaired for what you can just buy a new one for.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Black line down page when faxed or copying
Open up the document feeder and clean the scanner glass
Mar 27, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
ok no prblem check your scanner if it is dirty just clean scanner.dirty scanner may cause black copy .or scanner is dead replace it with a new mian jee
Dec 11, 2008 | Office Equipment & Supplies
Faxing is clean, streaks occur when copying
Open the document feeder cover. The scanner glass is dirty or you have a bad scanner block.
Dec 05, 2008 | Brother IntelliFAX 4100 Laser Fax
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
107 people viewed this question
