Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi projection tv wont show picture
Have sound but no picture
4 Suggested Answers
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
maatmartin7
  • 1210 Answers
SOURCE: Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Posted on Jul 12, 2009
My mitsubishi tv wont show a picture but it will make sounds
Hello, there are several things, a bad ballast board that provides the lamp with it's voltage to run it. Also a bad power supply can cause it. a bad Color Wheel will also stop it from coming on, if you heard a high pitched squealing sound before it went out, the color wheel would be my best guess.....tks
Jan 29, 2015 | Mitsubishi WD-65731 65" HDTV
Has sound but shows no picture
These types of TVs eventually need to have the bulb replaced. There should be an access door marked on it somewhere. Google your tv brand and model to find a replacement bulb.
Nov 26, 2013 | Mitsubishi VS-45605 50" Rear Projection...
Red status light is on but not blinking and picture wont show at all???
access the self diagnosis feature by pressing the menu and device/input buttons on the tv both together and hold them for 6 seconds then counr the teo digit blink code.
Mar 11, 2013 | Mitsubishi WD-62725 62" Rear Projection...
I have direct tv but wont show no picture just the name of the show whats wrong?
Sounds like the audio is hooked up but the video cable is not. Look to see if the right plug is plugged in from the direct tv to the right plug on your tv. And check the cable and see if it is loose or coming apart that would cause it to not recieve a picture as well.The cable company might have something to do with this. Also need to make sure that cable going in the tv is going in on the input side not output side. Thanks
Oct 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Red light wont show picture
This is either a bad capacitor somewhere in the tv, or the very common power supply/high-voltage transformer.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
