Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
No power to my Hitachi 42Pd6600 plasma tv
I have checked all the fuse to and in the tv and they are all fine but when i switch tv on at the mains and the button i have no standby light on and nothing else works
any ideas?
  • 1 more comment
  • curt_swift Jan 21, 2009
    my tv has developed the exact same fault yesterday. Where is the smps on the tv and where can a replacement be found.
  • galauden Mar 03, 2009
    I just had my Hitachi 42HDS69 fail to power up last night. Where are the fuses and power supplies located? Does it require dismounting the TV from the wall?
    Funny thing is, it's still under extended warranty from Circuit City, but the 800# has been disconnected...
  • nickos1966 Mar 31, 2009
    the tv wont switch on from the power button located under the tv
The master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Posted on May 31, 2009
  • 54 Answers
Are your aware of the small pushbutton "master switch" which is located below the tv screen ? it is normally located on the right side about 4" from the edge. if turning this switch on doesn't fix it, replace the "smps"...switched mode power supply
Posted on Jan 21, 2009
Cant get it to turn on it was fine till my lad turnd it off
An internal fuse may have opened or there could have been spontaneous power supply failure.
Apr 27, 2016 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
My hitachi plasma 42 PD7800TA does not turn on ,not even the standby ,the fuse is fine ,dont know what else to do? thanks Tony.
The power regulator board in your Hitachi is not switching. It is an SMPS [Switched Mode Power Supply]. Normally for plasma TVs the power supply repair will be almost impossibele due to lack of component availability. If the fuse is OK, definitley the switching process has failed it it. There is an IC which oscillates at high frequency, whic its oscillation signals are given to MOSFET transistors to chop the incoming AC, converted DC voltage. These switched voltage is passed through SMPS transofrmers which it turn generates secondary voltages that goes to different circuit boards of your TV. The power board is the most important section in a Plasma TV. it must be perfect in every respect in terms of secondary voltages. If any one of this voltage goes over than specified, the main boar will get damaged. So it is adviced to replace it as card basis, rather than making "sugery" to it. The power supply board can be had from Authorised Hitachi Service centers. You just give the the exact model number of your Hitachi TV. They will give you the orginal power supply board. Never play experiments with Plasma TV. OK.
Jul 15, 2011 | Hitachi PlasmaSync CMP4202U 42 in. HDTV...
My Hitchai plasma tv (42pd6600) has died. Can I
Try unpluging it for fifteen minutes or so, and plug it back in. Sometime a surge or guide information will make go off.
Oct 10, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Plasma 50" acts like it has no power
is the main power switch on @ the bottom if so could have bad main fuse,or power supply bad
Jun 05, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
42PD6600 A
i have the same problem did you ever get this fixed??
Mar 19, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
TV Problem
Jan 25, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
1,220 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
