Question about Samsung HLT-5075S Television
Black line on bottom of samsung dlp television HLT5075 SA after replacing dlp chip?
Replaced dlp chip now have black line or space on bottom of screen
3 Suggested Answers
roety
  • 585 Answers
SOURCE: Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 09, 2009
  • 8457 Answers
SOURCE: Our 55" Samsung DLP television has white dots all
The DLP tv projection light engine is the cause.This problems,very expensive to repair or replaced the projection light engine.Samsung know about this flaw in the tv design.Talk to them,make a deal with them about it.Help u repair it.
Posted on Sep 27, 2010
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Jul 11, 2016 | Mitsubishi WD Televison & Video
I have white dots on my HL-6156 Samsung tv. Started with 4 and is now 10 wide spaced over 12 to 15 inches of screen. Anything I can do ? Set is 5years old.
The DLP chip needs replacement that what causes the white dots eventually they will fill the entire screen assembly. You can get the replacement DLP chip with instructions from www.tvrepairworld.com
Mar 21, 2013 | Televison & Video
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
I have a HL-R5067W Dlp. Turned it on and have verticle black lines. Eight lines then 1 1/2" space then Eight lines repeated across complete screen.
It sounds that dlp chip got defective and need to be replaced to fix the lines issue. Local tv repairman will help you to get it replaced if you do not have experience of tv repair.
Hope this info will help you.
Thanks.
Jul 07, 2010 | Televison & Video
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
Apr 03, 2010 | Samsung HL-R5656W 56" DLP HDTV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots that dominate the screen
i think you do have a DLP Television because this happens a lot whit samsun DPL White spots in the screen.
is it like this?
if it's a yes? its the DMD BOARD you need to replace this part!
here are 2 links hope you can use them
http://www.discount-merchant.com/SearchResults.asp?Search=dmd%20board
http://www.partstore.com/Part/Samsung/Samsung/BP9601670A.aspx?s=froogle
Nov 03, 2009 | Samsung Televison & Video
Samsung HLT-5075S Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
