Question about Clarion SRW3841 Coaxial Car Speaker
Subs not working but amp is
Hey my subs stopped working on me the other day so today I was checking found an un-related problem with the amp so I changed it out but am still having problems, I have even tried changing RCA cables from the deck to the amp, and checking the wires from the amp to the cone of the Sub but all was ok. They would stop before but come back on, either on there own or if I hit a good bump
  • 2 more comments
  • Jeremy Strong Jul 02, 2007
    Nope didn't work, I changed grounds and still no reponse from the Subs, the Amp still has complete power and getting power to the cones on the subs...
  • Jeremy Strong Jul 03, 2007
    I mean that I can touch the pen light to the wire going into the sub right up to where it disapears and still get it to light up, the subs aren't even responding to anything unless I remove the black wire from the amp and touch the penlight to where it connects to the sub then it trys to repsond (it kinda crackles for a second then nothing) I am only using one amp for both subs (if that is what you mean by running a seperate crossover)
  • sclower91 Dec 22, 2008
    My subs are only a few months old, and the other day they started cutting in and out and now I'm getting no sound. The amp is fine, the fuses are fine, the fuses under my hood and under my seat are fine, the wires aren't burnt or anything...I literally have no idea what it could be
  • AIRFORCEJLG Jan 10, 2009
    i have the same problem , i took my sub out to make room for the holidays and when i put it back in i get nothing , no sound. i have checked all the wires like 15 times , the amp and capacitor has power , i took the sub out of the box and check the wires and nothinnnng. im soooo frusrated . please helppppppppp
Sounds like a Ground problem on the amplifier earth connection to chassis, could be a little loose if so.. also check if the paint is scraped off, so there is good ground. Also check all positive 12+ on the amplifier if all wires is tight. Cheers mate
Posted on Jul 01, 2007
  • Jack pack Jul 02, 2007
    Sorry I could not understand the cones on the sub, do you mean the sub is in motion? but still no sound coming out from the Sub?
    Are you running a separate crossover if so.. is it before the amp or after the amp? And if not would you be able to tell me the frequency setting of any crossover that is going to Subwoofer Channel.
SOURCE:
Econo d5150 radio. What caused subs to suddenly stop working?
The subs probably were being driven too hard, overheated, and burned open the voice coils.
Feb 12, 2016 | Car Audio & Video
My sub stopped working today made a weird noise then cut out i had a 500w amp and 500w 10'' subtube i connected the sub to 3 other amp set ups all the amps work and power other subs but my sub wont make...
did you check the fuse if you have one on it. also u want to have more wattage on your speakers than your amp to protect from blowing your speakers.
Jul 29, 2010 | M-Audio Car Audio & Video
Subs and amp sat in my garage for a year. I just
check your subs by connecting them straight from the stereo. If they work then there is an issue with the signal comming from the stereo through the rca cables to your amp, check those. Try another amp if you can with those rca's or test the amp with a friends car, either way try to rule out everything until it points to the problem.
Apr 17, 2010 | PPI PCX-2200 Car Audio Amplifier
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
1300a, no sound, protect light
if u have the amp bridged un bridge it. chack an see wat the ohms are on the subs an make sure the amp is stable to carry the ohm load..if u have 4ohm subs one sub per channel then u shud be fine that wud make the amp see 4ohms but if u have dual voice coil subs it cud be the configuration of the subs..here's a link on how to wire subs hope this help..http://mobile.jlaudio.com/support_pages.php?page_id=145
Jan 12, 2010 | Car Audio & Video
I have audiobahn amp an 3 12inch subs my amp keeps kicking into protection whats my wiring opions mono amp adnot sure what ohm the subs are
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
Jan 06, 2010 | AudioBahn AW1206T Car Subwoofer
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Clarion SRW3841 Coaxial Car Speaker Logo
408 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
