Question about Vacuums
The brush on my Kenmore Pet Power Mate no longer spins. I opened it up and found the problem may be with the rubber band connecting the spinning parts. Where might I purchase a new rubber band for it?
  • Vacuums Master
  • 18,391 Answers
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
devocap
  • 201 Answers
SOURCE: hoover floor mate wet/dry - brushes do not spin
Hey there bankshots, if you look at the bottom of the head of the vacuum, you should be able to see the brushes. Their are some screws to remove to gain access to the inside of the bottom panel. When opened, you should be able to see the entire spinning brush assembly. On one side, there is an area which has no brushes and may contain the remnents of your belt which most likely is the problem. These belts are often replaced and not the sign of any thing to worry about. Replacements can be found at registered repair facilities. Alternately, a professional will do it for you for a modest charge. Also your warranty may cover this if your machine is less than a year old, or you purchased the extra protection from the seller. Good Luck!
Posted on Jan 28, 2008
reddevil6
  • 1673 Answers
SOURCE: rotating brush
Sounds like the brush roll has an end that is melted or frozen up so it won't move, in which case you need to replace it.
Posted on May 09, 2008
Agent Don
  • 310 Answers
SOURCE: Non spinning brush
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632342
Generic problem for all Vacuums
Non spinning brush
Posted by tillie14 on May 29, 2008
I have a Kenmore upright beltless that suddenly, the brush stopped spinning. Do you have an answer for this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Kenmore upright the belt is broken and needs replacing and you can take it to Sears / Kenmore or a local vac dealer and they can change it for you or you can attempt to do it yourself, usually it just takes a screwdriver and either a flat or a geared belt for less than $10.00 to $15.00 is an estimate.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 29, 2008
CorvetteKing
  • 108 Answers
SOURCE: Brush part not spinning
The hoover savvys have a reset button on the top of the hood, its to keep from destroying the belt. Simply press that button and the brush should start to turn.
If this does not solve the problem it is more than likely the belt (rubber band thingy :) ) in this case pull the bottom plate off again, but this time lift the brush out and slide it to the side and out from the belt. Then look inside the machine and get the belt off of the motor drive gear. Once the belt is out turn it inside out and make sure the teeth to the belt are all there. ( if they are not there will be burn marks.) If it is missing teeth simply replace that belt and you're back in business.
If it is not the reset and it is not the belt, some of those machines had bad switches in the handle. You will find that there is a circut board in the top handle which sends power to the vaccum motor but not the brushroller motor making it seem as if everything is running just fine. You will not be able to buy just the circut board, they come as an assembly and include the whole handle. Unfortunately there is no good way for someone unexperienced to tell wether there is power to the brushroller motor or not. In this case a Hoover service center would be able to assist you though you may end up paying a small labor fee.
Posted on Jun 05, 2009
Why is the pet hair power brush not spinning?
Amazon.com: Customer Discussions: Shark pet hair & power brush
www.amazon.com/...pet-hair-power-brush/.../1?_...
Amazon.com, Inc.Jun 24, 2012 - I needed the belt and couldn't find one so I used a black heavy ponytail band in its place and it works, I don't know how long it will last, but until I ...
My shark pet hair power brush tool will not spin - Fixya
www.fixya.com/.../t13829250-shark_pet_hair_power_brush_tool_will_n...
Jul 30, 2012 - Posted on Jul 05, 2015.
Sep 21, 2015 | Shark Rocket Professional Self-Propelled...
Brush is not spinning on the pet hair power brush
Those things work off of suction, which spins a cog wheel that rotates and spins brush via a small belt. Disassemble the brush and check belt. Make sure the apparatus is clean and free of debris
Jul 25, 2015 | Euro-Pro Shark SC-505 Handheld Steam...
My pet vac only pick up via the tools and the brushes are not spinning
1( test the belt , can be worn, and replace
2( test the power brush and clean, and replace if necessary
3( clearing the hose.
4( see the diagram.
5( test the motor if need Repair.
Sep 06, 2012 | Bissell Upright Vacuum - The Pet Hair...
The brush on my Pet Power Mate attachment for my Kenmore isn't spinning. can it be fixed?
In my case the brush was seized on the axle. A wad of pet hair had wrapped one end and melted the plastic roller a little, binding it to the axle. Take the powerhead apart; Pull the white ends off the axle; Push the axle out; ream out the holes in the roller ends with the proper sized drill (#12 or 3/16", I think...close is good enough); Clean any debris out of the roller and steel wool the axle if necessary; Light oil lube job; and reassemble.
Feb 02, 2012 | Kenmore Vacuums
A piece of string / cord has wrapped around my Kenmore spinning brush end on the 12 Amp Power - Mate. How is the best way to get the cord off?
Cut the string with a knife or scissors and pull it off. You can turn the brush manually to ensure you get it all.
Oct 03, 2010 | Kenmore 22313 Bagged Canister Vacuum
My Hoover pet cyclonic is no longer picking up pet hair
You need to replace the belt that drives the beater bar.
Jim
Dec 01, 2009 | Hoover Vacuums
Brushes not spinning in Wash mode
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
May 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes won't spin
The power wire may be disconnected
Apr 21, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
