Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
How to replace water filter in kitchen aid kfcs22evmso
  • 1314 Answers
SOURCE: kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
  • 115 Answers
SOURCE: change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
Posted on Jan 05, 2009
SOURCE: no water flow to the ice maker
Here's a kinda clumsy solution: I had a similar problem--for several years I'd manually pour in just enough water to fill the spaces. Sometimes the ice maker would then start to work again for a couple of weeks. We have hard water, so I assume it's a problem related to minerals building up somewhere.
Anyway, most recently, I had some cubes frozen in the bottom of the drawer so grabbed the drawer and pounded it in and out a couple of times, bumping it onto the back wall a couple of times. Voila, the maker started making cubes. Now every time I get cubes, I first pull out the drawer halfway and then shove it against the back wall. ...seems to work--the drawer is always filled to the brim no matter how much ice I take. It's been a couple of months now so seems to be working...
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: Ice maker in my Kitchen Aid side by side is not getting water
there is only 2 things that would cause this. either the icemaker is bad and not calling for water or the fill valve that allows the water to come into the icemaker is bad. how old is the fridge ? also check the ice maker and make sure it has not accidently been cut off inside. if this is the old type theres a bar that raises and lowers. make sure the bar is down. in the up position this would turn your icemaker off
Posted on Apr 15, 2009
Maytag317
  • 1136 Answers
SOURCE: water not working but ice does - kitchen aid superba
When you activate the switch, do you hear the inlet valve buzzing? If you do, check the container or tubing in the fresh food side and make sure it is not frozen. If you do not hear the valve buzzing, chech the valve. If it appears to be ok, then you will need to check the switch inside the door control panel.
Please let me know if I can help further.
Thanks
Vic
Posted on May 20, 2009
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
What happens to filter if fridge is off for a month? It is a kitchen aid french door with freezer bottom. will the filter go bad and need to be replaced?
As water sits at room temps its can cause your filter to go bad or even clog. I would replace the filter and flush the system after filter installed to clean out the supply line to the dispenser door.
Safety first, good luck
Jul 27, 2011 | Refrigerators
What is part number for water filter?
Hello there:
Water Filter
Item # 1017291
$35.75
Item # 1017291
img-descriptiontab-on.png Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Related Items:
Jan 26, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Mar 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Superba kitchen aide refrig red light for water filter wont go of
You just need to replace the light switch on the filter control panel. I hope this helps you out.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Change filter?
Jan 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
How to clean the water filter
according to kitchen aid reps, you can not clean the filter, you can only buy a new one from them for it. i have cleaned mine, but it is only a limited solution
Nov 27, 2008 | KitchenAid KCM511 Coffee Maker
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
