Question about Sony PlayStation Portable (PSP) Console
PSP 2003 laser problem
I have problem with laser on model PSP 2003 , the lens doesnt read and the red light is not there . I think ,that replacement of it could help.
But i dont know , what kind of laser i should use.
On ebay i didnt found for psp-2003. I found for psp 2000 . Can i use the laser for psp-2000 [ KHM-420BAA ] is it same ? Thank you . Tomas
  • falcons333 Feb 03, 2009
    I replaced the laser with new one but it didnt help ? Whats wrong , could it be somehow repaired ?
    Thanks .
  • 132 Answers
Yes. The lasers are all the same the only difference is the size of the actual UMD enclosure which is only different with the phat (slightly thicker) just make sure its the right UMD tray.
Posted on Jan 22, 2009
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
PSP doesnt read even with new laser
if the psp still turns on and the memory card reader works i suggest you pay to get your psp modded.with the psp modded you can play the games of the memory card with out even using the umd drive.i got mine modded a while backs and i love it you can even play emulators and homebrews.hopes this help
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Help
Hi Bvogel987,
You probably need a new UMD drive. I have seen this many times. Try the following to restore the drive.
  1. Turn the PSP-1000 on,
  2. Open the UMD door
  3. Press down on the black peg poking up at 8 O-Clock in reference to the disc spindle.
  4. You should see the disc spin, and Laser light up. If either does not, then you need a new drive.
  5. If they do spin and light up, Take a toothpick, and wrap paper towel aorund the tip of the tooth pick,
  6. Dampen the toothpick swab with a Windex type cleaner.
  7. Swab the laser lens, and move the lens with you finger or toothpick to the right a couple of clicks. Place a new paper on the toothpick and dry the lens.
  8. Test. If this did not work, you still need a new Drive.
I run www.PlayStationClinic.com and we replace PSP-1000 UMD drive for $47.00 including return shipping and handling.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
My psp is not reading the disc or if it does it is very slow and doesnt load, it makes a noise that sounds like it is being hit by a hammer, i think the laser is not working properly. help me
this worked for my ps2 i had the same prob. with psp off open the disc door . without touching the lens move the lens assembly on its track up and a few times return it to its original position and it should load if that dont work than something got inside ( like dirt, lint) or something is broke from being dropped and must be taken out with care
Nov 09, 2008 | Video Game Consoles & Games
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Hi there ive got a problem with my psp it doesnt want to read movies or games do you maybe know whats wrong with it
Hey abeyers,
One of the most common reasons why a PSP would not be able to recognize discs is if the lens itself has become dirty. Dirt, lint, and other objects can prevent the PSP’s laser from reading the discs correctly, which may (in some cases) prompt an error message.
You may wish to try cleaning the lens yourself to see if this resolves the issue. If you are unsure how to do this, you may always refer to the troubleshooting FAQ’s in your PSP owner’s manual documentation for instructions, or should be able to obtain a lens cleaning kit from a local retail store.
In the event that cleaning the lens doesn’t solve the problem, you may need to contact Sony directly for further assistance. Most manufacturers can provide phone technical support while the manufacturer’s warranty is still in effect, and some retailers are able to provide you with other options if you purchased any additional coverage (such as repair or replacement plans) that may have been offered at the time of sale.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 22, 2008 | Video Game Consoles & Games
HELP PSP WONT READ UMDS!!!!
hi i just fixed my sons it wasnt reading umd's every thing else worked so have a look were the threaded rod runs threw the laser, in the centre at the back of the laser there is a little tab with a stamped groove in it make sure the laser is up against the disk spinner when turned off push the tab against the threaded rod hopefully it has seated (you ned a good light plus i used long metal twesers to push it down, easier to see on 2000 model than the fat one but you can manage good luck)
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Umd problem
Hi amitpal,
Your Laser lens is dirty. You need to get some foam type ear swabs, not cotton, like Q-tip. You should be abkle to find these at a local drug store. Dampen the swab in something like Windex and swab the lens of the laser. Use the opposite end of the swab which should be dry to polish the lens delicately. This may get you back working again. If not your laser has much more severe problems, and probably needs to be replaced. In this case, click on "Repair Directory" at the bottom of this screen. Then on the next screen select "Video Game Consoles" Pick a repair shop to service your PSP. If you think you want to do it yourself, be aware it is very easy to damage the PSP beyond reasonable repair.
Jan 30, 2008 | Sony PlayStation Portable (PSP) Console
Psp laser problem
I will advise you change the board and have it tricked to a custom firmware it saves stress on the lens unit
Dec 14, 2007 | Sony PlayStation Portable (PSP) Console
Psp will turn on but will not read any discs old or new
Hi BubbasMom,
Bubbas PSP has a problem with either the UMD laser, or the mechanism that moves it back and forth. Open the UMD door and Clean the lens with a Q-tip lightly dampened with Glass Cleaner. Swab it with the dry end after you use the glass cleaner.
If that doesnt fix it. You probably have something jamming the Laser from moving. Sometimes you can clear this by forcing the laser to move some. You will hear it click a few times. Once you click it a few times on way or another. Try a UMD to see if that fixed it.
Nov 21, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
329 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
