Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark x3470 printer
Wife just chnaged out the printer cartridge & now cannot get the message " close door" to go away. Will not print because it keeps saying to close door. I dont see anything open & dont have the manual to look up the error in. Probley simple but just cannot figure it out. Any help appreciated. I have already unplugged it & turned back on & still getting same results.
Call Lexmark,we had the same problem. They sent us a new printer.
Posted on Jul 02, 2007
    Scholar:
  • 71 Answers
Either the cartridge didn't get seated properly or a tab on the door that pushes a hidden micro-switch is broken off, not aligned correctly or obstructed from going in to the slot. The tab is a non-assuming plastic tab that lines up with a hole in the housing. "If" it is broken, bend down the center of a paper clip to form a "T" and insert it into the hole. The "T" shape will keep it form falling through. You may have to tape it into place. This is a safety feature to keep you from reaching in while it is printing or about to start. So remove it before doing any maintanence.
Posted on Jul 01, 2007
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
How do I reset Lexmark x3470 incorrect cartridge error
Try to follow the steps below to determine what is causing the problem and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
Let me know if this helps.
Nov 25, 2011 | Lexmark X3470 All-In-One InkJet Printer
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
I have a Lexmark X3470 which uses the Lexmark 1 cartridge . I bought a replacement but the printer displays incorrect cartridge.
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!
Mar 17, 2011 | Lexmark X3470 All-In-One InkJet Printer
How do i remove an ink cartridge from lexmark x3470 printer
Power on your printer and lift the cartridge door on the top of your printer. The ink cartridges will move automatically to the center. When they stop, pull the ink cartridge towards you and up to remove it. Then, take the new ink cartridge, remove all the plastic covers and place it in the printer. Then close the cartridge door and you are ready to print again.
Feb 26, 2010 | Lexmark X3470 All-In-One InkJet Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
Please do not forget to rate my solution
Thank You
Jayson
Sep 09, 2008 | Lexmark X3470 All-In-One InkJet Printer
I'm looking for Lexmark x3470 cartridge for my printer.How many prints will i get from 1 cartridge? Is it a home delivery item? whats its price? Can it be easily installed?
You can order this cartridge at www.lexmarkstore.com. Use the cartridge finder toolbar:
- select all-in-one, Lexmark X3470, and then the cartridge.
The cartridge is currently $21.99 + shipping.
Aug 25, 2008 | Lexmark Office Equipment & Supplies
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
Feb 24, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Hello, always keep dockets. Could be a dud cartridge. Recommend clean unit with own printer program, especially a deep clean if you have this. Try cleaning manually with proper cleaning solution and cotton tip, where cartridge sits. Also, is the cartridge the correct generic equivalent of the genuine lexmark, you may have wrong no cartridge too. good luck, lilacgerry xxx
Feb 11, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
