Question about LG KC910 Renoir Cell Phone
My touch screen is not working properly?
When i press the 1 button it actually presses the 3 button can you help me please i am about to destroy this phone!!grr >=(
  • LG Master
  • 3,287 Answers
Go into "settings", then "touch screen" options and recalibrate.
If the calibration is too far off, you may be able to "walk" it back by touching a point between the crosshairs and where you estimate the phone *thinks* you're touching.
Repeat several times and eventually you should be able to press directly on the crosshairs. You may want to consider using a thin (yet blunt) stylus to press perform the screen calibration for the last time to be sure you're right on the mark.
Posted on Jan 09, 2013
SOURCE: help u880 lg
hey there, I have actually got a u880 phone. It is stuck with a 3 symbol on the
Posted on Oct 16, 2007
  • 221 Answers
SOURCE: initial programming needed
under settings, go to phone settings, then NAM select, then select NAM1
Posted on Nov 11, 2008
SOURCE: LG Secret shows "unlock" on screen
Hi! I bought the phone yesterday, and as far as I can see, this "unlock" refers to the touch pad. When you press "yes" you should be able to to do things in the menu while the slide of the phone is closed. It locks itself again in a few secs (I think 5) so you have to unlock it again if you were idle for more than 5 secs. And I guess that could be personalized, to lock itself again in 10 secs or whatever. And if you want to use the menu without clicking all the time, try to do things with the open slide. Hope this helps.
Posted on Dec 09, 2008
TanyaAD138
  • 77 Answers
SOURCE: I can't check my voicemail...HELP!
There's a setting in your phone called HTMF tones. That needs to be on.
HTMF tones is what converts button presses into information an automated system would understand ... If it gives you an options of either long or short ... short is usually standard.
Hope this helps.
Posted on Mar 26, 2009
  • 320 Answers
SOURCE: My touch screen won't work.
Try to turn off the cellphone, remove the battery for 5 minutes then re-insert the battery and try again. If the touch screen still doesn't functions try to restore the factory settings.
Posted on Nov 19, 2010
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
I did a reset on my 7210 officejet all in one. And now the display language are in a foreign language (i think japanese). Now how do i change the language back to english? Maybe you can instruct me a...
1. Press SETUP 2. Press 7 and then press 1 This select Preferences and then select Set Language & Country/Region Scroll through to English using the right arrow key > 3.Press OK 4.When prompted press 1 for yes. The country/region for the selected language appear. Press right arrow key > to scroll through the list 5. Use the keypad to enter the two digit number for the appropriate country/region. 6. When prompted, press 1 for yes You can print a Self Test Report to confirm the settings 1. Press SETUP 2. Press 2 and then press 6.
Jun 08, 2011 | HP Officejet 7210 All-In-One InkJet...
I have an n73 and i forgote security code dj_samy19@yahoo.com please send master code here is my imei: 356425025567529
format the phone ....--->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
Jan 12, 2010 | Nokia N73 Cellular Phone
I cant format my nokia3500.....it is askin me 4 a security code wen i try to restore...i tried 12345,0000,00000.....pls help
Try to format it
Option 1: --->>*#7370#
Option 2: --->>
Option 3:
*#7780# -Restore factory settings
Option 4:
*#2640# -Displays security code in use
Jan 11, 2010 | Nokia 6300 Cellular Phone
CELL PHONE REPAIR
I tried this in 6600 too...So it will work..
Hope this will help you....Thank you...
Nov 13, 2009 | Nokia 6600
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Program Extension Name and change time on phone.
Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Sep 23, 2009 | Panasonic KX-T7633 Corded Phone
Change the time on the KX-T7633 pnone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jul 10, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
How to change time
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Nov 06, 2008 | Panasonic KX-T7633 Corded Phone
LG KC910 Renoir Cell Phone Logo
46 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
