Question about WYSE Winterm V30 Thin Client - Thin Client - VIA C3 - 128MB RAM - 64MB Flash - Windows CE 5.0 Network Terminal
Winterm v30 can't display resolution i set
My monitor said to set resolution to 1366x768. That wasn't an option, so I chose 1068*768 (I think) 85 MHZ Now the monitor is black when the terminal boots up. It displays during the boot process, but when complete, there is nothing on the display, so i can't change the settings back. Wyse support had me reset to Optimized Default Settings, but it didn't help. They also said to repeatedly hit the "g" key during boot, but that never worked.
4 Suggested Answers
HITESH
  • 20 Answers
SOURCE: No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Posted on Jul 24, 2007
  • 1602 Answers
SOURCE: Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Posted on Feb 06, 2009
SOURCE: WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Posted on Apr 07, 2009
There is no 1366x768 resolution item in setup menu for my monitor using.
Hi , your computer may only be configured for a generic display monitor which may not support your desired resolution . If so install the latest display's inf ( driver ) file and then after restarting access the display resolution applet and configure as per the recommended setting
I think here might have useful software
http://www.asus.com/Commercial-Monitors/VS197D/HelpDesk_Download/
Aug 06, 2015 | ASUS Computers & Internet
"Input not supported" even though it appears to be displaying correctly.
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
Apr 21, 2015 | Planar Computers & Internet
Page seems to be too wide for monitor screen. when centering up down & sideways either I lose some on the left or right of screen or a little on both sides. How can I shrink display Now I have only art...
It sounds like the resolution on your machine is set too large for the screen. Right click somewhere on your desktop where there is no icon. Assuming you are using Windows 7, there should be a Screen Resolution option in the little menu that appears - click on that, then try changing the resolution to 1366x768, which may even say Recommended next to it in brackets. If that still doesn't seem right, try some of the others, until you are happy with the display.
Hope this helps.
Jul 25, 2011 | Compaq Presario CQ56110US Laptop
I cannot find the resolution on my computer, the resolution required for the monitor is 1366X768, which is not available in my display settings. please advise how to set the...
If it's not available on your PC, then find one that will work. You will need to look at the book for your TV to see what it does support and look for one in your PC that is in the list.
Apr 22, 2011 | Computers & Internet
I am using an LG W1941S PF monitor, after using 2 yrs, the LCD Panel had to be changed. Previous optimal resolution was 1360x768 but after LCD replacement, it has changed to 1280x768. There are many more...
Hi, I would check with the repair shop that replaced the panel as it should register as 1366x768. The repair shop could have put in a different resolution panel and controller that didn't match the original and that's why you aren't seeing the 1366x768 option. Also worth noting is that often you can buy a new monitor of the same or better for less than what it costs to have it repaired. For example you can get a 20" scepter 1600x900 monitor from Amazon for $70.
Dec 26, 2017 | LG W1941S-PF Monitor
When i installed windows 7 in my laptop.my screen resolution decreases,so what can i do to increase my screen resolution?
first right click at desktop background, then click personalize, then click display setting, after that chose resolution that you want, for example 1366X768 then click ok
i hope this helpfull, please rate very helpfull if you think this helpfull, and don't rate if you think not helpfull
thanks for using fixya
Jan 20, 2011 | Computers & Internet
Ihave viewsonic lcd monitor va1616w. Display card is NvidiaGEForce2 integrated GPU. The resoultion is not coming correctly
Maximum resolution on this monitor is 1366x768. Check your color depth( 16 bit, 24 bit, etc) and do not set the resolution greater or you will get unpredictable results.
Brock
Sep 16, 2010 | ViewSonic VA1616w 15 inch LCD Monitor
I can not get the resolution of 1366x768 for our new monitor.
1366 x 768 is a widescreen resolution. it depends on the monitor if it supports this resolution.
Apr 22, 2010 | Computers & Internet
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
Problem with WYSE Winterm 3235LE
Tsaukpaetra is correct it's a resolution mis-match with the monitor you are using. If you have Rshadow loaded on the winterm you can VNC into it and change the resolution. If not you can hold down the letter "G" on the keyboard to perform a factory reset.
Aug 29, 2008 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm V30 Thin Client - Thin Client - VIA C3 - 128MB RAM - 64MB Flash - Windows CE 5.0 Network Terminal Logo
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
