Question about Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
Jet pump and spa heat enable on their own - Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
  • Todd Jan 15, 2013
    There are no timers set for anything other than the filter pump. Thanks though!
  • 372 Answers
Check your time settings. It sounds like the Spa Mode has been set to run at given times and with heat enabled the heater will automatically turn on when the the spa is activate.
Posted on Jan 12, 2013
Jet not running & spa not heating.
check to see if recirculation pump is running that one heats spa
Jan 25, 2016 | Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Feb 15, 2009 | Jacuzzi Pool & Spa
Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux)  RSP8 () Logo
70 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
