Where us wireless switch? fo HP Dv5z 1000? - Computers & Internet
  • 4 more comments
  • Marty Jan 09, 2013
    thanks, but .. Didn't indicate where the wireless button is located.
  • max carson
    max carson Jan 09, 2013
    Is this a new laptop, to you? Open Device Manager, Network Adapters, Does this HP model have a wireless Adapter? Open Control Panel, HP Wireless Assistant. Try here:http://h10025.www1.hp.com/ewfrf/wc/docum...
  • Marty Jan 10, 2013
    Bought the laptop in 2008, doesn't have a network adapter, Wireless Assistant is working. All troubleshooting guidelines say that the wireless button needs to be turned on. Can't find the button. None of the keys on the keyboard acts as a wireless button.
  • max carson
    max carson Jan 10, 2013
    In the HP Wireless Assistant You can't turn it on? You have had this laptop for 4 years and you have never located the wireless on/off?
  • Marty Jan 11, 2013
    No Help ...
  • 7,627 Answers
Take a look at this user manual: http://h10032.www1.hp.com/ctg/Manual/c01487709.pdf
Posted on Jan 09, 2013
Hp mini 1000 does not seem to recognize my wireless network and the wireless network light will not come on. What do I need to do?
The front of the HP Mini 1000 Netbook has two switches and two small lights. The two switches are for power and wireless. The two lights are for hard drive activity and power. Both the power and Wi-Fi switch are designed exactly the same. They are flat with a little bump where a light is.
Check if the switch is on before trying to reinstall the driver.
Hope this helps!
Apr 13, 2011 | HP Mini 1000 Netbook
I have a HP netbook mini and for some reason it has become disabled I am told to click on the wireless button but do not know where to find it. can you please help
if I remember correctly this laptop has a wireless switch right below the right hand side of the palmrest. the opposite site of the power button.
Jan 05, 2011 | HP Mini 1000 Netbook
My hp mini 110 will not wirelessly connect to the itnernet. it is the same network that my old laptop connected too,but it says it is unable to conncect. now it shows that there is not network available....
Did you see a switch on the side of the HP machine or a key on the keyboard with a wireless symbol? Turn on that switch or press the key to get wireless adapter started. Then try again to search for wireless networks. Please post if the issue persists and I will help on that.
Nov 26, 2010 | HP Mini 1000 Netbook
Low wireless signal strength compared to other computers - the netbook consistently reports about half the wireless signal strength that a Dell laptop sitting next to it does. in low signal strength areas...
For HP Mini 1000, the wireless device can be problematic.
I will recommend the HP Mini 210-1084. This has the fastest wireless in the HP Mini range of Netbooks.
Good luck.
Jul 17, 2010 | HP Mini 1000 Netbook
NEED TO REPLACE LEFT SIDE TOUCHPAD BUTTON ON DV5Z STILL WORKS BUT IS VERY LOOSE
Most likely it is more convenient to just replace the entire palmrest. The palmrest has to be taken off anyway to get to the touchpad and buttons. Palmrest assemblies go for around 25 bucks on Ebay.
Sep 27, 2009 | HP Computers & Internet
My pc pavilion has wireless capabilities. How can I get it on
make sure that you have the wireless switch/button in the "on" position. go to wireless networks and refresh to find the available networks. If this does not work, you might have a fried wireless card
Dec 05, 2008 | HP Pavilion N5150 Notebook
Xp or linux couldnot load in my laptop
I've successfully installed XP SP3 on a DV5Z (custom build). Here is what I did, you will need to check that your DV5Z has the same components before using these drivers.
Step 1 Create an XP boot disc
Get the AMD motherboard/SATA drivers slipstreamed into an XP SP2 installation disk. I use NLite for this from http://www.nliteos.com
Drivers are available at:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_DownloadFile.aspx?FileType=Driver&FileID=3517
Other forum posts have more information on how to create the disc but I found NLite pretty easy to use. I suggest slipstreaming the SP2 patch into your installation disc.
Step 2 Install XP
Install XP from a Bootable disc you created using NLite. Get XP working and upgrade to SP2 if your installation disc wasn't already SP2.
You should see all the devices now in Device Manager in XP, but with exclamation marks.
Step 3 Get the XP drivers/software
The HP Compaq 6735s shares many components so you can get many drivers from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3687622&prodTypeId=321957&prodSeriesId=368762
1&swLang=8&taskId=135&swEnvOID=1093
Audio UAA bus driver sp33867 Install this before upgrading to XP SP3
HP Software update sp38874
Synaptics touchpad sp39032
Wireless assistant sp39374
Quicklaunch 6.40F1 sp39425
XP SP2 updates sp39429 I guess these will be in XP SP3
Driveguard software sp39602
Webcam driver sp39606
Driveguard driver sp39738
AMD CPU driver sp40535
AMD SATA driver sp39719
The following is on other laptop models but you can just search for it manually or use the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-62438-1&prodTypeId=321957&prodSeriesId=3687621
Audio IDT driver sp39671
Drivers from other sites:
1) Realtek Ethernet driver
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
If the link doesn't work you want the PCI Express versions fromhttp://www.realtek.com
2) AMD Dual-Core Optimizer
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_14098,00.html
If the link doesn't work look around on http://www.amd.com
3) ENE CIR driver version 1.3.306
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/MSI-GX600-08-ENE-CIR-Driver-133060.shtml
I found that the 1.3.306 Vista driver works fine on XP but newer Vista drivers do not. I couldn't find an XP driver
4) Atheros Wifi AR5008 driver
http://www.atheros.cz/
5) Realtek Card Reader
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=15&PFid=25&Level=4&Conn=3&DownTypeID=3&GetDown=false
If the link doesn't work look around on http://www.realtek.com
6) ATI graphics
Get these from http://www.ati.com you need to get the Integrated chipset version if you have HD3200 graphics.
7) Realtek Audio Codec
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I installed both the ATI HDMI Audio device and the Windows XP driver, you may only need the ATI HDMI.
Step 4 Installation
Install the drivers first (after devices have been detected), then the software. You will need to force install some of the drivers by going through Device Manager but most of the drivers have installation programs. CANCEL ANY DETECT HARDWARE DIALOG BOXES TO AVOID AUTO-INSTALLING THE WRONG VERSION OF A DRIVER.
You will also need to carry out a registry fix for the wireless LED. Copied from another post:
"For the Wireless LED its a little trickier. If you can find the root directory for your wireless network adapter like Paddy MacSeamus mentioned above its pretty simple. Follow his directions until you find your Wireless Network Adapter listed next to DriverDesc. In that same directory, i.e., 0003, add these Dword values just like you did above:
New-> Dword
Value Name=gpioFunc0ActHi and Value Data=0
Click Ok.
New-> Dword
Value Name=gpioPinFunc0 and Value Data=3
You are done. These values should be seen in the same window as DriverDesc and the name of your Wireless Network Adapter. The LED will work correctly after you disable and re-enable your wireless."
After doing all this, my DV5Z works correctly except for the following:
- Mute button LED always on orange
- No on-screen display of volume/mute etc. You can use Microsoft Intellitype (use the Digital Keyboard device and download this) instead of the HP software - see other forum posts if you need more info on where to find this
- QuickPlay key doesn't work. Presumably this can be fixed by installing the QuickPlay software for another notebook eg DV6000 series but I've not tried this
One final thing - I was given incorrect SP details by an HP person on an online chat session and told to refer to manufacturer websites for other drivers. The latter is incompetent but acceptable in my view, whereas the former is clearly unacceptable (why give out incorrect details on their own drivers and pretend they're doing me a favour?).
Oct 31, 2008 | HP Business Desktop dc5700 - Intel Pentium...
MSA 1000
Turn off MSA and cluster, turn on MSA and only one server, you will be able to access the data
Oct 17, 2008 | HP StorageWorks MSA1000 Network Storage...
Computers & Internet Logo
David Payne
David Payne
