Question about Toshiba MK3259GSX 320GB SATA300 5400RPM 8MB 25 SATA II Hard Drive
Does not recognise when cd is inserted
Toshiba MK3259GXS
  • Toshiba Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Posted on Jan 09, 2013
Cd drive is not recognised,therefore cannot boot by cd or reformat hdd
external cd rom drive that is what I did for my friends laptop that doesnt even have a cd rom drive but I had to crack the password and had to use a disk to crack so i hooked up a ezdub external drive and that worked
Sep 24, 2009 | Toshiba Tecra M2-S630 Notebook
The drive is not being recognised by the laptop - the yellow light on the outside casing of the drvie is constantly on, the eject button will not work and can only be opened by inserting a paperclip in the...
The drive is bad and needs to be replaced. The latency you experience in loading XP when the drive is connected is because the computer is attempting to recognize the drive and it cannot.
Jun 30, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba Tecra A4 version 1.70 has 'lost' 'Sonic' from 'all programs' so Now I can't burn DVDs.
I hope you made your restore disks for your laptop when you got it... You need to reload Sonic...
Apr 13, 2009 | Toshiba Tecra A4 Notebook
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Aug 27, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
DVD/CDRW drive not recognising any DVD's
The Laser Light Reader is out of adjustmjent or is very dusty. Manufactures will not fix the problem if the product in out of warranty. Your only choice is to consider it a CD-RW reader/writer only or buy a new one.
Sorry.
Jun 04, 2008 | Computers & Internet
My Toshiba U300 is not recognising when i insert a CD
not at all? even if you go to my computer and double click the cd drive?
Apr 02, 2008 | Computers & Internet
I am unable to write data onto a CD OR DVD disk in my Toshiba satellite series laptop
disk? like a 3.5 disk? or a CD?
if its a cd.. it must be a CDRW.. that means that its a special disk that can be rewrite able..... so your disk must be CDR.. you can see more here : http://en.wikipedia.org/wiki/Cdrw
if its a diskette, there is a little thingui in the corner that then you move it, it can be rewriteable.you can see more here http://en.wikipedia.org/wiki/Diskette
Dec 18, 2007 | Toshiba Satellite A105 Notebook
Toshiba MK3259GSX 320GB SATA300 5400RPM 8MB 25 SATA II Hard Drive Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
