Question about Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-05VFL2
HOW TO remove bulbs from bathroom fan FV-LP0003
2 Suggested Answers
pyroshain
  • 42 Answers
SOURCE: Our new bathroom fan is not clearing the room the
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Posted on Jan 23, 2010
I have a 3 year old Panasonic Whisperlite FV-08VQL4 ceiling fan for the bathroom, with two CFL bulbs (18W each). One of the two bulb locations is bad -- it won't turn on, regardless of replacing the bulb...
Sounds like a loose wire inside the unit. But, I would try this. With the power off, both switch and circuit breaker, try and bend the center contact for the light bulb out; pull it out away from the back of the socket. This may be the bad contact. The center contact on the bulb touches this in order to get power up into the bulb. Using a small screw driver, try and scrape the surface of this contact to clean it a bit. DO ALL OF THIS WITH THE POWER OFF!!!
Hope this helps.
Sep 05, 2010 | Panasonic FV-08VQL4 Fan
How to lower the sound on a bathroom fan
One needs to install a bathroom fan that has a Sone rating of 1 or below. They aren't cheap :-( Sorry, there really isn't any other solution.
Dec 18, 2009 | Panasonic WhisperValue Bathroom Fan...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Replacement bulb for Panasonic FV-11VQL4 does not fit
YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
Mar 12, 2017 | Panasonic Kitchen Appliances - Others
How do u remove the cover to change the bulbs on panasonic whisper-fit low-pro?
The cover is gently pulled down.
It only comes down so far, as it's held up by springs.
There are four springs. Two on each side. To gain more clearance on one side to replace the bulb/s, you disconnect the end of two springs on one side.
After the bulb/s are changed out, reconnect the springs, ease the cover back into position.
Oct 01, 2009 | Panasonic WhisperFit-Lite Low Profile...
Odors backing up
Those fans are only designed to remove steam and high humidity from bathrooms to prevent mold.
Aug 11, 2017 | Panasonic FV-05VQ3 WhisperCeiling Fan
Odors are backing into the bathroom after installing the whiperfit
try to install the fan at a lower height so that it can drive out all the smoke. This is because the fan can driveout air with in a certain radius and installing it at a lower height increases it..
Jun 16, 2008 | Panasonic FV-05VQ3 WhisperCeiling Fan
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-05VFL2 Logo
74 people viewed this question
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
