Question about Sewing Machines
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Im really getting frustrated with my pfaff qe 4.0..i had a pfaff for 26 years,LOVED it and may manymany quilts on it. this one is beautiful and I want to get on with it, but nothing stops things like needles breaking!!!!
  • Sewing Machines Master
  • 7,365 Answers
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Posted on Jan 09, 2013
SOURCE: My Pfaff 4.0 breaks needles
a sewing machine I work on last week, I put a new needle in the needle clamp & thought I had it correctly inserted,, but it wouldn't work,, so I went back & checked the needle again & found I had to unscrew the needle clamp screw even more than normal to insert the needle then it work perfectly.
some needles & thread don't work togeather--here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are for lint
& also in the bobbin area for lint & loose threads
Posted on Nov 18, 2010
SOURCE: Just bought a brand new Pfaff Quilt Expression 4.0
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Posted on Apr 01, 2011
  • 17 Answers
SOURCE: The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Posted on Aug 15, 2010
  • 1788 Answers
SOURCE: pfaff quilt expression 4 It shreds
Are you using the right needles, size and type? Before, you wreck your material, take it in and have it serviced. I know everyone hates to pay for service, but if you like your machine it will be worth it to have it running at its peak. Just like a car, we spend tons on them but expect a sewing machine to never need anything. Remember, it is worth it.
Posted on Sep 13, 2010
  • 8 Answers
SOURCE: I have a Janome 1600P
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Posted on Apr 21, 2011
Needle hitting bobbin casing on Pfaff Quilt Expression 2046
If you have installed a brand new needle and it is still hitting, then the machine needs an adjustment. Take it for service.
Apr 01, 2017 | PfaFF Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
NEED A MANUAL FOR PFAFF QUILT EXPRESSION 4.0
Just search the internet for:
Make + Model + the word "Manual"
Pfaff quilt expression 4 0 Manual
May 31, 2016 | PfaFF Sewing Machines
Needles keep breaking when embroidering.
Needle breaks
Oct 17, 2013 | PfaFF Quilt & Craft Pro 7530
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 23, 2013 | Sewing Machines
Pfaff quilt expression 4 It shreds thread when free machine quilting and will not cut threads with the cutter. I need to be able to fmq without worrying. I have had a new cutter and keep cleaning...
Sep 12, 2010 | Sewing Machines
Thread breaks
If the thread is feeding from the spool without hanging up, the problem is within the threading system.
If this machine auto-threads, try to manual threading.
Call your dealer and tell them what is happening and you need their assistance. The machine may have to be serviced. Take a sample of the problem with you.
Too many bells and whistles can sometimes be, too many bells and whistles!
Mar 14, 2010 | PfaFF Sewing Machines
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
Oct 21, 2009 | PfaFF Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Sewing Machines Logo
105 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
