Question about Vacuums
Bissell ProHeat Pet Makes a popping sound and stops sucking up water
I can cut it on and it will throw out and water and the solution just fine and it also picks up the water just fine. But after a few mins it will make a popping noise and then just stops sucking up water. Its almost like something got caught in the air way but we have checked it and can't find anything wrong.
reddevil6
  • 1673 Answers
SOURCE: Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
Usually if the water isn't being sucked up is either the filter in the lid of the tank is clogged, or the gasket that sits on top of the clear window nozzle and the tank is missing.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: bissell 1699n proheat clear view problems
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Posted on Jan 17, 2008
SOURCE: water suction
Here's what I did. On the top of the water bucket there is a red oval screen, remove and clean the screen and replace. Also, next to the screen is an oval opening which meets up with a black oval gasket on main unit. Inspect the gasket and replace if dry or cracking. Otherwise, if it looks good, reseat the gasket (it fits into some grooves). When you fill the bucket and put the the top on, put it in the machine and make sure it is making good contact against the gasket. This worked for me. I also found a repair manual for these units that could be helpful located at: http://www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on May 24, 2007
SOURCE: bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Posted on Dec 14, 2008
nwj2468
  • 76 Answers
SOURCE: my bissell want **** up
somewhere on the unit, there will be a round clear cap. when you find it, unscerw it and clean out the inside.
Posted on Mar 01, 2009
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat pet will not suck up water
Check the filters. User's Guide has locations. one under water tank cap one under Flow Indicator. They are small but need to be cleaned after each use.
Jul 18, 2014 | Bissell Pro Heat Orginal belts
My bissell will not suck the water
Check User's Guide for filters. One under the water tank cap (looks like a small screen) and one under Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jul 18, 2014 | Bissell Proheat 2X Select Pet Upright Deep...
Cleaning the tubes on the heater of a bissell proheat pet
just simply take a half a bottle of bleach poor it in the clean water tank use the hose and sprayer on a clean hard surface it will spray the clean bleach and suck up clean bleach and the bleach will do the job for you
Mar 18, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Bissell proheat pet expelling too much water
Hi Jessica. If you're experiencing continuous spray, you may want to have one of our Authorized Service Centers inspect your machine.
Here's a link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Sep 21, 2013 | Bissell 9200P Deep Cleaner, ProHeat 2X Pet
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat carpet cleaner is not sucking up the water. How do I check the pump belt. The motor sounds fine. Thank you
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 05, 2010 | Vacuums
I think my bissell proheat 2x is plugged up with pet hair.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
rrtjgh
Sep 05, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
673 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
