Question about Dell OptiPlex GX280 PC Desktop
Gateway screen stops at power saving mode
Lost power during tech support signal hookup,regained good signal , but can not get passed saving mode on screen. Will change to gateway screen in cycles,but nothing else??
  • Anonymous Feb 18, 2009
    help my computer wont start up it just goes to power saving mode
    Novelist:
    Champion:
  • 201 Answers
Try This
1 Start tapping F8 while poering on the PC
(Don't stop tapping until you get to the advanced boot option menu
2.With the arrow key(up & down) go to Safe Mode With Command Prompts <Enter> chose Operating System <Enter> Signin as ADMINISTRATER
Note: this should get you to a command prompt window with a blinking curser
3.In the (Black) Command prompt window type chkdsk /r <Enter>
4. you will get a message stating the valume is in use and can not be used would you like to set a chkdsk on reboot <Y> <Enter> and reboot PC
On Reboot the PC will go thru a system check. This will take several minutes.
5. after the chckdsk is complete reboot the PC you should be able to access you profile to signin
Posted on Jan 21, 2009
How to Use Shutdown, Sleep, Hibernate Modes for my Laptop?
Shutdown is safer, close all program.
Hibernate is good for long period (e.g. stop during the night). All the data will be saved on the HD.
Suspend is similar to Hibernate mode, but data are copied to the RAM, so if you aren't conneted wtih power cable and battery goin to 0%, you will lost your work that aren't saved.
Oct 18, 2016 | Computers & Internet
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
No Signal!!!!!
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 30, 2012 | Cell Phones
Stuck in analog power save mode. cant get passed black screen.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you might try
During the boot process tap the f8 button repeatedly this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps you
Sep 12, 2011 | Computers & Internet
My moitor is stuck in power save mode. I have done everything..I don't know what the problem is
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
hope this helps
Jan 07, 2011 | Gateway 500XL PC Desktop
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Dell OptiPlex GX280 PC Desktop Logo
155 people viewed this question
Alun Cox
