Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer is sqeaking
Dryer squeeling while drying clothes
  • Official Brand Answer
  • 4,342 Answers
Hello jodysmomma - Sounds like you either have a problem with the belt, front and/or rear bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replace depending if they are worn, damaged or loose.
Posted on Jan 10, 2013
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
Clothes Dryer makes high pitched sqeak
Most driers have to be disassembled from the back and work your way forward. Try that.
Feb 03, 2014 | GE DCVH480EKWW 4.0 cu ft electric dryer
Sqeaks when drying clothes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | Dryers
DRYER MODEL # YG20JN2 SQEAKS WHEN DRYING CLOTHES. DOESN'T DO IT ALL THE TIME, BUT GETTING MORE FREQUENT.
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
idler pulley, belt may be wearing:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | Magic Chef Dryers
I have a GE Dryer model type 333/453/473 and I recently noticed a ''sqeaking'' noise near the motor. Does anyone know what might be causing this. Do I need to lubricant something. The dryer still dries...
this noise is usually due to the ideler pulley going bad and should be replaced but until then take the back off and spray the pulley with some sillicone
Aug 23, 2009 | Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer help
Pop the top and get the front off. Get the ball of lint out the blower housing and replace the bad blower wheel.e00d80d.jpg30eaeb0.jpg
Dec 16, 2008 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
