Question about Western Digital My Book Home 500GB External USB 2.0/FireWire/eSATA Hard Drive
Wd my book 500gb external is not being shown on the computer what so ever. Is also making horrible clicking sound
  • Western Digital Master
  • 27,725 Answers
You can gain access to a working hard drive that is inaccessible when the system starts and assign it a drive letter under the Windows Explorer interface. Or, you can import foreign disks into Windows or create a partition and format them. You can scan a drive for bad sectors or lost clusters and repair the system files to allow access to a corrupted drive. In short, you can utilize the drives as they were intended to be used by completing some operating-system configuration steps that are occasionally required for some drive installations.
Click "Start" (the Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Tools" tab and click "Check Now" under the Error-Checking section. Select both check boxes to allow the system to automatically fix file-system errors and to scan for and attempt recovery of bad sectors. Allow the system to run the scan the next time the system is booted. Restart the computer to complete the scan and check for access after the scan completes. Click "Start" (Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Security" tab and click "Edit" to change permissions for the drive. Click "Users" from the Group or User Names section. Check the "Allow" box for full control and check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the left column of the inaccessible drive and click "Import Foreign Disk" to allow the system to convert the disk signature to a local disk. Check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "Change Drive Letters and Path." If no letter exists, click "Add" and assign a drive letter from the list of available letters. If a drive letter is listed, click "Change" and select a new letter to eliminate any conflicts with other devices in the system. Check for access after these settings are in place, which may require a restart of the system. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "New Simple Volume" to create a partition and format it for use. Click "Next" when the New Simple Volume Wizard appears. Click "Next" to accept the maximum for the drive. Click "Next" to accept the suggested drive letter assignment. Click "Next" to format the volume with the suggested defaults or change them if desired. Click "Finish" to format the drive and make it accessible to the operating system. Hope this helps.
Posted on Jan 09, 2013
  • 341 Answers
SOURCE: Flashing light on WD 500GB External Harddrive
This may sound silly,but sometimes if you put the drive in the freezer overnight it will work long enough for you to retrieve your data.Make sure you are ready to copy the data to another as it will likely fail again once it warms up.
Posted on Nov 26, 2008
SOURCE: my computer does not detect WD 500GB external hard drive
It may need to be plugged into a powered USB hub to get it to work.
I've had the same problem on certain PCs and plugging it directly into a powered hub resolves that problem. I picked up a small powered hub just for that reason that I keep with my drives.
Posted on Mar 19, 2009
  • 5 Answers
SOURCE: Western Digital 500GB My Book Essential won't start up
To save your data from a bad Wd Ebook you need to download UBUNTU and burn it to a cd. Boot from the cd. Do not install Ubuntu just click try it out. When it loads turn on your Ebook and iit should appear on the desktop. If not click the places tab on top and find it there. Right click the EBook and mount it. Now you have access to all the data on the ebook. Iy yoou have enugh space n your cpu hard drive save it there, if not you will need another surce large enought to copy the data to.. I have used this method to save many hard drives, flash drive and other unreadable media. if the drive is totally toast you are out of luck but this method works moost of the time. Any questions drop me an email.
Shayne
Posted on May 01, 2009
SOURCE: How do I completely remove the WD Sync software
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
Posted on Jul 19, 2009
  • 109 Answers
SOURCE: How to format WD Passport 1TB to FAT32
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Posted on Dec 24, 2009
Wd 500gb hard drive is not shown any power it was working fine suddenly when i try to connect to my laptop nothing appearing. plz advice
Good day, this video tutorial will help you to recognize your WD 500GB. Just follow instruction and your problem will gonna fix.
Jul 30, 2011 | Western Digital My Book Essential 500GB...
PC and laptop will not recognize WD external drive. I have Window Premiun 7 new PC and noticed my pictures were being saved to My Pictures in PC. I do not want them saved there so unplugged WD then deleted...
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | Western Digital 500GB My Book World...
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Dec 24, 2009 | Western Digital My Book Essential Edition...
WD 500Gb HDD not showing up in my computer, etc
Maybe the best thing to do is,
1) Remove WD External while pc is switched off
2) Reboot into windows
3) Doenload Ccleaner > http://www.homepc-security.co.uk/Downloads%20&%20Tutorials.html Then install.
4) Make sure you have Cleaner highlighted on the left near the top. Then put cheque marks in all boxes except, Windows Size/Location Cache, User assist History & Wipe Free Space then click Run Cleaner. Once you have repeated the step of running Run Cleaner till nothing else appears, then select the Registery cleanerthen click Scan For Issues and delete all that you find there also. Turn off pc, remove power cord then push the on button to discharge the pc, then plug in the WD Hard drive via a diffrent usb port, and boot up pc. I hope this works for you.
Jul 27, 2009 | Western Digital My Book Essential Edition...
WD external Hard drive
sounds like a conflict to me.
controll panel / system / hardware tab / device manager. then find the device and right click / properties.
Jul 14, 2009 | Western Digital 500GB My Book World...
My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Jul 10, 2009 | Western Digital 500GB My Book World...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Mar 10, 2009 | Western Digital My Book Essential 500GB...
Western Digital My Book Home 500GB External USB 2.0/FireWire/eSATA Hard Drive Logo
49 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
