Question about MTX Thunder 2-Channel Amplifier 502 Car Audio Amplifier
Won't power on, but blade fuses are ok,
My amp just stoppped work and all the blade fuses are ok and I have checked that all the wireing is correct and it is. I pulled the cover off to look with a pen light tester, and I think that 2 out of 3 of the small black resisters/capacitators/fuses or what ever they are are shot because only the outside one will light up the pen light, are the other two supposed to work simultaniously to the outside, and is it worth it to track down replacements and have someone fix it?
  • Jeremy Strong Jul 03, 2007
    The remote wire works fine, I put another amp I have in and it powers up
I dont know about the resisters but i had that proublem and it might seem to easy but check your remote wire coming off the deck (cd player)
Posted on Jul 02, 2007
SOURCE:
2004 escalade speakers work but not left side balance on deck is ok all chiming sounds are from left side Are there fuses on central amp Fuses in hood ok Fuses in dash ok
If your wires are hooked up correctly then it is possible you have blown a channel in your amp or head unit , the amp does have its own fuse but most do not have a fuse for each channel it either works or doesn't . Only other possibility is somehow the amp has been switched to mono .or "bridged" these settings are used when the amp powers only one channel or a subwoofer
Oct 13, 2015 | Cars & Trucks
Why won 't computer communicate with code checker
Check the cigarette lighter fuse. This is what powers the DLC. If the fuse is good, check and see if the lighter works. If not, you have a bad wire. Code readers have to have power from the car. Most scanners have there own power and will read the computer, unless the data wire is bad or the computer is bad.
Mar 28, 2015 | 1995 Buick LeSabre
Marine radio keeps blowing a fuse
Follow instructions for wiring up speakers. If you don't have instructions https://soundcertified.com/speaker-wiring-diagram-guide should help Now, turn off the radio Double check your power source and wiring to find a short from the battery to the radio. Turn on the radio to see if it is now ok. I am almost 100% sure you have a short somewhere between your battery and radio. Make sure you have the pos. and neg.wires in the right place.
Mar 30, 2013 | Pyle Boating
My Kenwood A-51 amplfier won't play music when connected to speakers.
http://www.agtannenbaum.com/k_cat.htm#KENWOOD manual here..........meder's tv service
Sep 10, 2012 | Kenwood Audio Players & Recorders
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
Hi iam having an electrical problem after jump starting car at first i put the jump cables wrong way round !! then corrected error started car ok but had a fuse burn smell ! sho checked everything and...
check all positive wires coming from battery sounds like you melted one and it's touching something it shouldnt, Thats what u smelled, clean and tape damaged wire(electrical tape) check wires behind fuse block also
Aug 30, 2011 | Hyundai Excel Cars & Trucks
My rear lights for some reason are not working properly... i have power in the dark green and yellow wire only when i push on the brakes. Also i have no running lights of blinker lights... i checked the...
GRREN WIRE FOR RIGHT TURNS YELLOW FOR LEFT TURNS BROWN WIRE FOR BRAKES AND RUNNING LIGHTS WHITE GROUND WIRE CHECK THE FUSE FOR YOUR STOPP LIGHTS IN YOUR FUSE BOX SOUNDS LIKE ITS BLOWN LOL POHLCAT
Mar 03, 2011 | 1987 Chevrolet S-10 Pickup
I have a 2007 ford five hundrd the blower stoppe working, all fuses have been checked and are fine. Any ideas
Fuse 35 (40Amp) Front A/C blower motor, this is under the hood in the power distribution box, is it ok? if it is, the most likely problem is either the AC blower speed control module or the blower motor itself, jump 12 volts to the blower and see if it runs, if it does and the fuse is ok, replace the blower speed control.
Nov 29, 2008 | 2007 Ford Five Hundred Limited Sedan
MTX Thunder 2-Channel Amplifier 502 Car Audio Amplifier Logo
85 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
