Question about Kitchen Ranges
Buzzing control panel on Whirlpool Gas Range
The touch pad control unit on my Whirlpool gas range is making a constant buzzing sound. The warranty has expired and I'm wondering if this is dangerous. The oven less is than three years old and to have someone come in will cost $179 plus parts. The model number of the oven is XFG374LVB1. Is this something that I can fix?
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 09, 2009
Why does my electric range makes abuzzing noise every few minute
How do I find out the cause of a low frequency hum in my ...
answers.angieslist.com > Home > Other
May 6, 2013 - Can hear it a bit outdoors in the back of my house. ... Edit Answer (for another -17 minute) ... floor in each room of the house - water sourced noise goes a long ways, ... 8) - gas control valve or electric control box on a gas furnace, or its ... These will commonly make a hum or wheeze sound, for only for a few ...
Induction unit makes buzzing sound - Seasoned Advice
cooking.stackexchange.com/.../induction-unit-makes-buzzing-sound
Mar 1, 2011 - But my accidental activation rate is still well above acceptable on all ... So if the buzz is normal for induction cooking today, why did they ... gas ranges vs induction ranges with some notes on which pans worked ... A good service and re- positioning of the fans on their axles always clears my noise problems.
Dec 29, 2015 | Kitchen Ranges
Why does my whirlpool gas range have buzzing noise from control panel
Probably have a bad transformer on the control board. You would have to replace the control board.
Sep 02, 2014 | Whirlpool GS460 Gas Kitchen Range
Why does Control panel constantly buzz on a HotPoint RGB744 and RGB745 whenever it is plugged in.
Could be a faulty solenoid coil on the gas valve, or a relay you may need to remove the front panel and have a listen be careful it's live power . Use a multimeter to test through the circuits an disconnect the item that's buzzing, there is your problem.
Good luck and be careful
Ray
Jun 03, 2014 | Hotpoint RGB745 Gas Kitchen Range
Kenmore range
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&!!
Jul 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
possible to have abad relay on the circuit board itself, only real way to fix is to replace the control board assy
Nov 04, 2008 | Kitchen Ranges
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kitchen Ranges Logo
291 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
