Question about Behringer MS40 Digital Monitor Speakers 2.0 channel 40W RMS
I want to change fuse on behringer MS 40 speakers
I used a US system accidentally in UK and may have blown the fuse. I need to change it
2 Suggested Answers
Grubhead
  • 5342 Answers
SOURCE: I have a Behringer GX-212
Disconect the speakers from the amp and apply a 1.5 volt battery accross the terminals for split second. If the speaker pops then they work. And there's something up with the unit.
Posted on Jan 09, 2011
Accidentally plugged my b212d in wrong voltage,now when put it on its makes a tiny cleeking sound and the power light dosnt come on.what should i do
Unplug the unit and replace the fuse. Same wattage and type as the one you remove.
If you've already done this, then you've destroyed other components inside.
Aug 04, 2016 | Behringer EUROLIVE B212D Active 550-Watt...
Power light is on but no speaker output?
Disassemble it enough to get to the speaker to check for continuity. If it's blown, replace it, If not, the amp board is probably blown and needs to go in for repair.
Mar 08, 2016 | Behringer Eurolive B205D Active 150-Watt...
How to connect Behringer qx1200 mixer with pc and pc/speaker? I tried all solutions but i didnt' get any sound. Earphones works great
the mixer connects to the pc via usb or analogue i/p's
the mixer does not connect to the pc speaker
this has to be done with the software you're running on your computer
the easiest way is..plug the headphone o/p into any amplifier line i/p
( amp and speakers or powered monitors ) and forget about the pc speaker ..they're sh!te period ..or you can plug the headphone
o/p into the mixer then the mixer into an amp but this is more complicated and you will need to read up on it
but do yourself a favour and get some small multimedia speakers
similar to these for starters http://www.ebay.co.uk/itm/GENIUS-BLACK-MULTIMEDIA-STEREO-SPEAKERS-SYSTEM-for-LAPTOP-DESKTOP-PC-COMPUTER-UK-/250929417549?pt=UK_Computing_Speakers&hash=item3a6c8f0d4d
May 28, 2014 | Behringer Audio Players & Recorders
B115D
Hi, your amp has a short if the fuse is blown - it needs to be repaired - we can fix it - look on ebay. Thanks.
Mar 12, 2014 | Behringer Eurolive B115D Powered PA...
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Nov 05, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
The fuses have blown due to a short circuit, ie some part acting like it was a piece of wire. The chances are (with the LED's showing) it's the main amp semiconductors (on the heatsink) that have gone. The cause is either connecting a wrong (unsuitable) speaker(s) for the job, or letting the two wires (to each speaker) touch each other.
Mar 28, 2010 | Behringer EUROPOWER EP2500 Amplifier
Speaker wires accidentally touched.
it sounds like the cone in the centre has blown. Use a 'spare speaker' not one from the system and try it, is should work, but if it was the centre speaker cable that shorted, should you get no sound from the spare it sounds like you have blown that part of the system which will require professional repair. Sorry
Jan 17, 2010 | Yamaha HTR-6030 Receiver
Behringer MS40 Digital Monitor Speakers 2.0 channel 40W RMS Logo
131 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
