Incline isn't going all the way up or down. Only moves a few inches
RUN the software calibration see the steps. The
Steps for Newer Style Console Calibration Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.) Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed). Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21. If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools. Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL23 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL24 should display
in the TIME window and (??) in the SPEED window. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window. Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill. Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position. Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
However lube+clean the elevation motor, shaft and gear, and adjust the small POTentiomenter for fix it.
God bless you
SOURCE: The incline setting on my Proform 550 Epic View is
The incline adjustment is done this way in your machine: a motor is attached to the platform with a hinge; at its shaft is attached a worm screw; on it there's a threaded bushing which is attached to a lever situated on an rotating shaft - when the motor turns the bushing is moved up the worm screw which pushes on the lever which rotates so it lifts the platform
If you can hear the motor turning but nothing happens it means that this mechanism is faulty:
1 - the connection between the motor shaft and the screw has broken - fix it
2 - the friction in the bushing and the joints is too much for the motor - clean and oil thoroughly the entire mechanism
3 - the screw or the bushing are damaged - replace them.
Unfortunately finding replacement part will be difficult -this is an older model that is no longer in production.
SOURCE: My T81 treadmill quit working. All of the lights
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Testimonial: "Thank you soooo much! Now I have somewhere to start and try to figure this out!"
SOURCE: horizon t40 incline is stuck
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Watch the block diagram, main controller board ha 90% aprox of functions of the treadmill. sincerely.
SOURCE: INCLINE ADJUSTMENT ISN'T WORKING
Watch the videos +TIP:
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedoBSERVED THE BLOCK DIAGRAM that I did for people like you, for to instruction, look how the main controller has aprox 90% OF function in any treadmills.
Good luck. sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
