Question about Plantronics CS60 Professional Headset
CS60 ear peice with heavy static when in use
When using the phone receiver there is not static but when using the ear peice there is heavy static on both ends of the line.
This just started about an hour ago.
Is it shot?
  • Anonymous Feb 04, 2009
    I have the same issue. When using the earpiece there is loud static. My coworker is having the same problem. Both units are just over a year old and cost over $500. Do we need to replace the earpiece, the battery in the earpiece, or the entire unit?
  • 83 Answers
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
Posted on Jul 18, 2009
Mitel Superset 420 corded phone has static
Static on the handset of a MITEL phone is indicative of either a defective handset cord **OR** the user has one of those cord detangler devices attached to the cord. If it's a cord detangler, remove it, smash it with a hammer and throw it away. Advise the end-user to please not use these as they all become staticky after several weeks use. If the user has problems with their handset cord constantly becoming tangled, THAT PROBLEM is indicative of neck or ear fatigue from frequent LONG CALLS and the user keeps moving the handset from one ear to another (changing hands). THE FIX FOR THIS is to give the user either a corded or cordless headset (or check SMDR records for excessive personal calls)
Feb 12, 2014 | Mitel Superset 420 Corded Phone
Hi, we use the plantronics cs60 headset at my place of work and the earpiece stopped working so i have changed it for another one and i have paired them together but now when i pick the ear piece up the...
It would depend on what headset you actually purchased. You say CS60 but it may be the Plantronics CS50 or CS55 headset. The headsets are not interchangeable. If you are not sure what headset you have, simply look on the bottom of the base for the part number. On the headset you can read what part number that is by very carefully looking under the battery. Here is a link to open the battery.
Here is a link to the CS60 instructions to replace the battery.
I think that if the base and the headset are the same it might be that you may need to subscribe or pair it together again.
Here is a link to the CS60 subscription and pairing instructions.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics CS60 Professional Headset
Ear peice broken
NO,sir basically Ear peice is not repaired
Mar 15, 2011 | Samsung Rant Cell Phone
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Ear peice problem for nokia5800xm
Probably not compatible with your phone. Try getting a new ear piece or your phone might have a software issue.
Mar 18, 2009 | Nokia 5800 XpressMusic Smartphone
I have a CS60 Handset doesnt work when the headset is connected
First setup the headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
Jan 27, 2009 | Plantronics CS60 Professional Headset
Plantronics Problem with my headset
Setup the Plantronics CS60 wireless headset as follows:
To be able to hear or speak through the headset, press the call control button on the side of the headset. The talk indicator light on the base should go on and the green light on the side of the headset should be blinking.
Jul 21, 2008 | Plantronics CS55 Wireless Headset
Sound
well i think your ear peice is gone the speaker
Jul 05, 2008 | Motorola Mobility V547 Cellular Phone
Connecting headset to phone
Jun 16, 2008 | Plantronics CS60 Professional Headset
Ear Speaker Problem
Sorry to say - there's no fix for this. You have to get a new phone.
Jun 09, 2008 | Palm Treo 650 Handheld
Plantronics CS60 Professional Headset Logo
332 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
