Question about Exercise & Fitness
I have an E6 error on my Marquee MT8.12 treadmill. we have tried to recalibrate but nothing happens
    Top Expert:
  • 12,223 Answers
Please follow the steps and fix it.
causes:safety key faulty +elevation motor not moving+elevation motor screw binding.
solution: replace the s.key +check connection motor +clean and lube the screw
Run again the s. calibration see the steps.
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Posted on Jan 09, 2013
  • Braam Bosman
    Braam Bosman May 12, 2014
    Add a CommentI keep on getting the E6 error even after I have cleaded the motor connections and gresed the screw,m I actually have to turn the screw by hand to the lowest setting to get the tredmill to run as normal and not trip after 30 sec.It seems like the limits is not letting the electronoc board know that it has reached it,s target altough it stops after one level up request and even if I go up a level it allows it to do so but wont go back down and wont run for more than a few seconds and then E6 comes up.Can it be the motor or elect5ronic board?
4 Suggested Answers
johnklee845
SOURCE: Moved treadmill to new room
wtf, no solutions to this???
Posted on Feb 24, 2012
ercupa190
  • 12223 Answers
SOURCE: Sportsart 1200 treadmill E-6 hoe do you recalibrate it?
read the instruction under HOOD motor and proceed according . OTherwise go to the instr. manul and follow the steps for how to enter the s. calibration
if you do not have the manual go to www.fitness.manualsonline.com
God bless you
Posted on Nov 30, 2012
ercupa190
  • 12223 Answers
SOURCE: error6 on my treadmill
please see the problem and fix it. see the block diagram
circuit diagram attached.
Happy new year. God bless you
skfsyaaaaaelftksuqmcc
Posted on Jan 01, 2013
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 04, 2014 | Exercise & Fitness
Treadmill marquee mt8.12, e6 error. looking for owners manual
go and download free www.fitnessmanualsonline.com
causes: key safety+ elevation motor connection+screw binding.
solution: repair or replace s. key + test the connection e.motor + clean and lube the screw e.motor.
God bless you
Jan 08, 2013 | Exercise & Fitness
VISUAL FITNESS t97005 e6 ERROR CODE
LUBE THE deck belt, this happen because lack of maintenance, do ti
2( lube the rollers bearing too
3( test the input voltage motor, if there are the motor need repair
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 24, 2012 | Dmm Vision Fitness T9500 Treadmill
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
My lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Oct 19, 2011 | Exercise & Fitness
Error E6
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Exercise & Fitness Logo
117 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
