Question about Compaq Computers & Internet
Can i put my compaq presario 2200 hard drive on another laptop..if so which one?
My old laptop..has lots of old family photos and video i want. computer has power but nothings comes up on the monitor its just black. i was told to remove the hard drive and put into another laptop to get all the data from it.
  • Compaq Master
  • 5,419 Answers
You should place the drive from the Presario 2200 in an 2.5" external enclosure or use a USB/SATA/IDE adapter. (If you want to use an external enclosure, you will need to check if your drive has a SATA or IDE connection and get the correct type.)
If you replace the drive in a working laptop with the non-working drive, you will probably get the same issue. The error suggests that the Presario can't find an OS on that drive. At best, you will see errors due to drivers and Windows seeing a new CPU and motherboard.
When you connect via a USB connection, you be able to attempt to find the files on the old drive. This will be slow (limited by the USB speed). If you had a desktop, you could get faster transfers. If there is a free 3.5" bay, you will need a 2.5" to 3.5" drive adapter. Then you would need some adapters for the IDE connection to the motherboard (if the old drive is IDE and the motherboard supports IDE). Make sure the drive is on the "Slave connection" of an IDE cable and set for Slave or Cable connect. There are IDE to SATA adapters or PCIe cards that will support adding drives if your motherboard can't accept more drives.
Good luck. I hope this helps.
Posted on Jan 09, 2013
  • 236 Answers
SOURCE: Compaq Presario R3000 not booting up
set the bios/cmos to boot first of your CD drive. get your support discs and restore to original. your hard drive OS has failed and needs to be re-installed. the problem maybe is that when you do that option you will get all your data erased. your solution to that since you can still get the data on the drive when used as external is to back it up. then full restore your system.
if you dont have your restore kit, you can use your Windows OS to fix it, repair option when you boot from CD.
Posted on Apr 02, 2008
PABLOCSA
  • 1124 Answers
SOURCE: hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Posted on Nov 05, 2008
ArmyMason
  • 121 Answers
SOURCE: remove hard drive in compaq presario laptop f572us
Please see link for Detailed instructions. Its simple as unscrewing a few screws and sliding out the hard drive.
Posted on Apr 01, 2009
ICmanServer
  • 129 Answers
SOURCE: compaq presario cq40 how do i remove the hard drive
Hi..
If you want to remove hard drive of your unit. Be sure that do you have little idea to do it with your own. You need to remove first the screw of your unit to open the back cover. Once you are already open the cover, you can remove the hard drive slowly.
Regards
ICmanServer
Posted on Aug 12, 2009
SOURCE: My Compaq Presario F732NR Laptop w/Vista won't Boot.
You have done an excellent job of diagnosing a MotherBoard fault. This is undoubtably the problem. Have you removed all/any cards attached too, like say the WiFi?
Posted on Feb 08, 2010
Presario 2200 hdd not being detected
This is not good, remove the hard drive and reseat it back in place, sometimes that is enough to get it going, if no change! the hardware may be open and if that has been determined you will need a new hard drive.
Mar 28, 2012 | HP Compaq Presario 2200 Notebook
How do I remove a Compaq Presario 2200 forgotten drivelock password
If you forgot the password of the hard drive I'm afraid there is no way to access the drive any more. This password is used to encrypt the hard drive entirely, and without this key there is no way to decrypt the files or access the drive.
Jan 31, 2011 | HP Compaq Presario 2200 Notebook
My Compaq Presario 2200 powers on ("on" led, drive
1) put the laptop on a bed or a similar surface to close the air openings below
2) wait some time (15-30 min or 1hour) and let it get warm enough
3) restart.
it worked for mine. hope it works for you too.. the laptop seems stable and does not give any more beeps (for now).. good luck !
Jan 02, 2011 | HP Compaq Presario 2200 Notebook
What is the largest drive I should put in my Compaq Presario 2200 PC Notebook?
Usually the drive which can be put in your machine depends on what you want to use the machine for. But usually to attain optimum performance it is advisable to put in a hard disk in accordance to the RAM on your system. The ration of RAM to hard drive should be about 1 Gig Ram to 100Gig Hard drive. This should help you decide what size of drive to put.
Hope this solution has been helpful?
Nov 30, 2010 | HP Compaq Presario 2200 Notebook
How do i remove my compaq presario 2200's hard drive?
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard drivemag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Aug 08, 2010 | HP Compaq Presario 2200 Notebook
Need to switch out hard drive
Go to Youtube and look for your type of computer there, and include the words hard drive in the description. There will be several videos showing how to do it, even if your specific model isn't shown. It really is easy to do, once you've seen it done
Sep 25, 2009 | HP Compaq Presario 2200 Notebook
Hard drive failure compaq presario 2200
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
Hard drive problems.
You,ve got a couple Of options Here.
1: you can replace the hard drive with a replacement, install windows. Then add the corrupt drive, and attempt to access it That Way.
2: You Could attempt To Repair, the Hard-Drive With A Tools-Disk. Containing partition Managers Et,c.
3: you could try starting your computer, with Windows Operating System Or Restore Disk In Drive D:/ Or CD/DVD Drive, In The hope That Windows will re-install, overwriting any corrupt Or deleted Files, And restore your Drive To It,s Original state.
4: you Could send your Hard-drive To Me, Where I can attempt Data Recovery For You.
There Will Also Be Other Problems posted.
Mike @ compurepair.
Feb 28, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
