Question about HP Pavilion dv8000z Notebook
Laptop overheating and shutting down
Gets warm very quickly (after about 30-45 minutes) then shuts down and it takes about 5 minutes before I can turn it on again. It's a Compaq, about five months old
  • 1,800 Answers
Most likely proseror fan is faulty checkt and replace it
also power supply's fan.
Posted on Jan 20, 2009
    Brigadier General:
  • 5,158 Answers
You need to take it apart enough to get at the fans and heat sink and clean out the dust and dirt.
  • 177 Answers
CPU IS OVERHEATING AND OVERWORKING MIGHT BE A VIRUS OR A HANING PROGRAM
My toshiba windows vista ultimate gets over heated an d shut down itself foe every 5 minutes what to do
Please check the internal exhaust fan for malfunction. For temporarily you can use external exhaust fan to prevent it from overheating while use the laptop.
Regards
Jan 20, 2011 | Toshiba Computers & Internet
Computer shuts off after a few minutes
Hi daddyo1269. That problem could mean that the laptop is overheating, probably the fan is not turning on and the CPU temperature can rise very very quickly and it shuts down in order to protect the CPU or the motherboard. After you turn it on, turn the laptop upside down and check the fan. If the fan is spinning propertly then the motheboard is "short" for some reason so you have to take it to a repair shop. I hope this helps and dont forget to rate.:D Thank you.
Apr 28, 2010 | Dell Inspiron 700M Notebook
Laptop gets warm near touchpad , shuts down
Sounds like it is overheating and then shutting down. Is the laptop on a hard surface or a lap or blanket? You need to have air circulation.
Mar 13, 2010 | Medion MD 96340 Laptop
My laptop gets heat and shutdown
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Feb 27, 2010 | Compaq Evo N610C Notebook
My laptop keeps shutting down at random times. I
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba m205 4806 shuts down spontaneously. The lap top feels warm but the fan is running. any suggestions?
The cpu get overheated and will shtdown to protect it. The fan continues to run until a CPU safe temperature is reached / sustained.
1. Use laptop on flat surface, not on pillow, carpet, bed, etc. that will restrict air flow. Using a can of compressed air, clear the air vents.
2. If the symptom continues, then the heat conductive paste between the cpu chip and the heatsink is no longer effective (hardened, too thin, etc.). Remove the heatsink and add thermal paste
($6 Radio Shack).
Sep 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Battery and/or overheating or ?
It is possible that the battery is not charging at all and can't pass electricity to the board. But if its 3yo, its probably really dead.
Also, if you can see a fan not working at all, overheating is also possible.
It is also possible that there is a tiny foreign object capable of conducting electricity, such as human hair, that gets activated at the slightest movement of the laptop by shorting some pins on your board.
So I would suggest to observe more or clean the inside of your laptop if you know how to remove your keyboard.
Apr 28, 2009 | Computers & Internet
Help !!!!my laptop shuts down
We had some Acers do the exact same thing and we fixed them. I believe it shuts right off as a safety. Usually when the processor gets too hot it powers right off to save the laptop from burning up. First quick fix it to blow out the vents and especially blow out the heat sink vent. Also could be that the heat paste that sits between the CPU and Heat Sink could have dried up and stopped doing it's job to remove heat efficiently from the CPU. Big problem in earlier model Gateway laptops too. This can be fixed by acquiring some paste from a local tech shop and reapplying it. If you feel unsure about it, take it to a tech shop and they can do it quick for cheap if not for free. Keep me posted - Scotty
Apr 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
HP Pavilion dv8000z Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
