Question about Microsoft Xbox Console
Center light flashing red and green
Sometimes when I put in a game the xbox will start to load then it will reset and the center light wil flash red and green and no picture wil show up
If you have not "opened" your Xbox (taken the case off the main unit) and you are having problems, think about calling 1-800-4MY-XBOX that is the customer support number for Microsoft. If you have had it less than 90 days it should be covered under warranty. If you open the unit they will no longer fix your system for a reasonable charge and it will be cheaper to buy a new one. Check out some of the light errors here http://www.llamma.com/xbox/Repairs/xbox_motherboard.htm It depends on your exact sequence of flashing lights as to the exact problem. Hope this helps.
Posted on Jul 01, 2007
Sometimes the console will not load to the screen where the big (xbox360) icon, the lights around the on/off button flash profusely and it seems as though the screen has frozen. if the loading gets past...
Those are common error on the XBox 360, after some extended use. You can try to send it to be repaired, and if it happens again, consider the purchase of a newer model.
Mar 01, 2011 | Microsoft Xbox 360 Console
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
1 red light, xbox 360
i dont know what it is
but i can tell this
go 1st to a game store and they wil thel more about it
Sep 21, 2009 | Microsoft Xbox 360 Console
Xbox power light blinks and freezes xbox
That flashing green light meens there is a problem with the power to you DVD drive. the power is being interrupted. ie, when you have power the welcome screen will load and when it doesn't it will shut off. you don't have continuos power. For example if you have the power cable unpluged and then plug it in with the power on the xbox will reboot. Check the wires and the port on the motherboard if all is ok you need a new drive.
Jun 24, 2009 | Microsoft Xbox 360 Console
Wireless controller wil not sync with xbox 360
turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
Feb 18, 2009 | Microsoft Xbox 360 Wireless Controller
My new hand control just flashs green all the time
When you tried to use the new controller did you sinc it with the Xbox? There is a very small button on the front of the controller at the center. You need to turn the XBox360 on, then your controller and press the small button at the center front. Your next step is to press the small button on the XBox360 console located to the left of the power button. Both the controller and XBox360 should start to flash until they sinc up.
Dec 09, 2008 | Microsoft Xbox 360™ Premium White Console
4 red lights flashing
The TV screen or monitor remains black when you start an Xbox 360 console.
This behavior may occur with or without a game disc in the disc tray. The console appears to be on because the green power light illuminates and the fan continues to operate. However, the screen remains black.
Click on the IMAGE i paste here below:
Thank you,
~micro
May 21, 2008 | Microsoft Xbox 360 Console
Flashing red and green light in xbox
You have a major failure on the motherboard. If it was your hard drive the system will boot up, but freeze on the main screen and you will hear clicking coming out of the hard drive. Red and Green flashing lights means there is a problem on the motherboard. Sometimes you can fix the problem by reflashing the Bios on the main motherboard.
Nov 11, 2007 | Microsoft Xbox Console
When i turn on my xbox is flashs red and green
well your tray is stuk it happens i usually push the eject butten then push in the disk and if thet dosent work i sometime hit (not hard) right above the disk tray and for your other problem try checking all the plugs and if all are good then it is most likly the inside of your xbox if you lost your warenty then i would look it up on google and see if you can fix it your self or send it to some1 (or u can buy a new xbox prices today are cheap $150-220)
Sep 02, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
91 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
