Question about Sennheiser E855 Professional Microphone
Sennheiser e855 wiring diagram - Sennheiser E855 Professional Microphone
How can I fix a broken cable inside a sennheiser mzh3040?
you have to unsolder the wires on the coil assembly then pull everything out through the bottom. replace the bad wire, reassemble the xlr end and resolder the wires to the coil.
Aug 05, 2014 | Sennheiser Audio Players & Recorders
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
Mini jack (3.5 mm) wiring schema. Thanks
Call Sennheiser. They have the wiring for their products.
Sep 18, 2010 | Sennheiser freePORT Wireless Instrument...
Aiwa turntable PX E855 squeaking may need oil
lift off the rubber platter, the turntable should just lift off but there may be a circlip to remove around the spindle if so use needle nose plyers.
When the turntable is off you should be able to see where the noise is coming from by using your fingers.
Only use light machine oil very sparingly
Nov 27, 2009 | Kitchen Appliances - Others
I want to wire an ECM 77 sony lav mic to an SK 100 G2 wireless pack by sennheiser. Can you send me a wiring diagram. Thanks for your time. Ray
Here is the standard wiring diagram for a mini XLR : http://www.smartwireless.co.uk/users/UserFiles/File/Pin%20wiring%20details%20for%20Smart%20beltpacks.jpg Have a look at this post:http://www.dvinfo.net/forum/all-things-audio/128889-sennheiser-sk100-jack-confusion.html If that doesn't help try this company for info by contacting them with your problem as they sell a variety of adapters:http://www.hosatech.com/contact/contact.php
Nov 26, 2009 | Cycling
How do i wire a mke2 gold dot onto a shure T4AF connector
Go to www.shure.com/faq and search for Sennheiser. The wiring diagrams are in the FAQ's.
Aug 23, 2008 | Sennheiser MKE2-60 Professional Microphone
My sennheiser headpahone is not working
I had that problem before. I thought something was bent. Actually all you have to do is make sure the headphone are pushed all the way up on both sides.
Mar 17, 2008 | Sennheiser RS 140 Consumer Headphones
Sennheiser E855 Professional Microphone Logo
50 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
