Question about Frigidaire Freezers
Compressor not runing
I got power to freezer but no power to compressor
    Sergeant:
    Champion:
  • 249 Answers
You need to call A&E FACTORY SERVICE @ 1-800-862-9226.
I mean now
Posted on Jan 09, 2013
  • Charlie Lapinski Jan 10, 2013
    if you want to fix your unit
  • Charlie Lapinski Jan 17, 2013
    did you called A&E FACTORY SERVICE yet
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Jul 13, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Frigidaire Freeze FFU1764FW0 failed after power brown out.
Yes a power brown out can cause compressor failure. More than likely If there was a power surge it is possible that the overload on the compressor opened. This is a safty device that helps protect the compressor. It usually resets itself but in the cause of a surge it may have burnt up. problem could also be in the relay or thermostat
Feb 27, 2009 | Frigidaire Freezer FFU1764
Danby 3.6 cu.ft. freezer is not freezing
the best is to check the wires at the compressor start device to make sure it has 120v and if it does the compressor is bad and if it doesn't the replace the themostat.
Larry
Nov 25, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refridgerator freezer not geting cold
Your compressor has shorted out. The compressor shouldnt be scorching hot just warm. And that humming you are hearing is the compressor trying to start but it is shorted. There is nothing you can do except for replace the compressor.(or the refrigerator)
Nov 16, 2008 | Whirlpool Freezers
Freezer is not running even the power receptacle is working
there are no fuses on a domestic freezer that i have ever seen. there are no fans and there are no traditional freezer coils. so you have only a few things that could be going on. if the temp is way up the thermostat should sense hot and close and send power to the compressor and it should run. you can do one of two things . find the thermostat inside the freezer usually . gently remove cover and check incoming terminal and outgoing terminal. if you show 120 volts its open and the stats bad. if you don't show 120 volts between terminal connections then its closed and the compressor is failing to start. if power is coming into the stat when checked to ground then go to compressor and see if there are starting components . they are a start capacitor and a START RELAY AND PERHAPS A OVER LOAD . SEE IF POWER IS ARRIVING AT THE COMPRESSOR. IF SO CHECK THE MICROFARED OUTPUT OF THEcapacitor . you need within 10 percent of the rated value. also you can gently remove the overload , a little plastic disc and look on the bottom side and see if its cracked or burned looking. an amp probe on the compressor will tell you what amps it pulls if it trys to fire up . 6 to 10 is good 30 to 50 is mechanically locked up and then the overload trips. if compressor is ice cold to touch then your not getting power to the compressor and its not trying to run. if its hot to the touch thens its trying but start caps weak , or its locked up. most domestic freezers are not worth the cost of a new compresssor anymore. good luck
Oct 31, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezers Logo
41 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
