Question about Minolta PagePro 1250W Laser Printer
PagePro 1250W-USB to Parallel cable converter does not work
Just purchase a new computer that does not carry a parallel port to connect it to my Minolta PagePro 1250W printer.  Purchased a converter cable to solve the problem, however the printer still does not work.  Any sugestions?
  • Minolta Master
  • 19,396 Answers
If your new computer has Vista, you need to download and install new Vista drivers,
Download drivers here.
Follow instructions here km vista instruct v2.pdf
1250e setup e.pdf
This printer has USB port, that is faster than LPT1 parallel port, and does not need an adapter, Use the USB port and cable and do not use any adapter, just a regular USB cable.
If for some reason you need to use a parallel port and adapter, read below, otherwise do only the above.
First ensure that the driver for the LPT adapter is properly installed, and that you have an LPT port on the computer.
Then re-install the printer drivers using the printer disk, verify that drivers are compatible with your new system.
Here is an example of adapter, I guess it is similar to the one you are using.
SATO 11S000154 External USB to Parallel Adapte
Posted on Jan 21, 2009
  • 8,197 Answers
Reinstall drivers here are the downloads.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1250%20w
Also you can get the manuals here to help walk you through.
http://kmbs.konicaminolta.us/content/support/supporthome.html
Posted on Jan 20, 2009
  • Jyackle5
    Jyackle5 Jan 20, 2009
    If you look at first link with the drivers the 3rd obne doun is for the usb port driver.
    Genius:
  • 2,920 Answers
Have you downloaded the rivers for the printer? you need them to make the printer work and it could be whats causing the problem
    Scholar:
  • 96 Answers
I take it this is a lead that connects the parallel port on the printer to a USB port? Did the adaptor come with any drivers and have you installed them?
Try a different USB port and make sure you are connecting direct to the PC and not through a USB hub.
These "adaptors" are a workround and not always reliable I'm afraid
    Brigadier General:
  • 5,158 Answers
Have you installed the printer drivers for it ?
  • Roberta Smith
    Roberta Smith Jan 21, 2009
    there are two types of cable... straight thru or serial... printers use serial cables i believe... is that the type of cable you purchased ?
    Robert
  • 296 Answers
Try just a straight usb printer cable
  • James Bradburn
    James Bradburn Jan 20, 2009
    also does the printer have the proper driver disc with it. If so you need to install the drivers. If driver are installed, try the program drivermax. It works wonders.
    www.drivermax.com
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
No parallel port on my computer. USB -parallel
This scanner is an old one so it has only parallel port. You can connect it to any USB with the converter you mentioned and should be working. Did you connect the power supply at the scanner too? It is nesessary for the scanner in order to take power.
Stelios.
Feb 22, 2010 | Canon CanoScan N640P Flatbed Scanner
Can the P2055d be connected with a parallel lead?
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
Dec 28, 2009 | HP LaserJet P2055d Printer
My new computer doesn`t have a parallel connection for my Canoscan N640P. Can I get something to convert to USB. Thankyou
yes, there are cables the will convert a parallel connection to usb. do a search in google for "parallel port to usb" and there will be some links to some stores that sell them.
Nov 24, 2009 | Canon CanoScan N640P Flatbed Scanner
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
Parallel dongle will not work with new system that only has USB connections
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Apr 16, 2009 | Computers & Internet
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Minolta PagePro 1250W Laser Printer Logo
149 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
