Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
I have a Frigidaire front load washer model FTF2140ES2 that will
I get beep code 3 Drum overfilled Inlet valve, pressure switch or control board failure. Is this common and what is the fix. Chart saws to restart - call for service
  • Anonymous Feb 24, 2009
    the door lock lite does not light up if u push start if flashs 3 times real fast but will not run i already replace the door lock swicth an the slect button wont change
  • timheller1 Apr 04, 2009
    Frigidaire front load washer Model # FTF2140ES2 beeps 3x.  Control light is on.  Will not start.
The rubber around the door tore and the washer leaks bad.where do i find that part.
Posted on Jun 21, 2009
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
Unplug it for 10 minutes. Plug it back in and see if it starts and runs normally. If it doesn't then I'd suspect the pressure switch first then the control board.
May 10, 2017 | Frigidaire Affinity ATF7000E Front Load...
sorry have no info on this model have you tried draining the mach manually then switch it back on i have seen this type of prob on other makes main control board is sometimes required
May 07, 2014 | Washing Machines
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Why does my my frigidaire front loader washer reads diagnostic code e30
Dec 19, 2012 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool duet 4.0 washer 3 weeks old suddenly beeps 3 times after start button will not run
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Catalyst washing machine, model #110.20056 992, that is triple beeping and only allowing one wash cycle type. Is there something I can fix on this?
Jun 19, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't start
Feb 01, 2009 | Kenmore Elite 45986 Front Load Washer
My washer constantly beeps three beeps
Dec 27, 2008 | Kenmore 46462 Front Load Washer
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
349 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
